Help needed - Dead battery
Old Jan 28, 2020 | 11:18 PM
BBR318's Avatar
BBR318
perhaps a bad alternator?
Old Jan 29, 2020 | 12:48 AM
PNW_IPL's Avatar
PNW_IPL
Had any rain lately? Hows your sunroof drain tubes.? Your ecu/bcm is located in the pass footwell when wet causes all sorts of electrical issues. Charging system is simple. Alt good batt good starter good. Check the ecu. Sunroof drains are a well known issue and fail leaving the ecu to.get wet and cause weird non diagnosable issues
Old Jan 29, 2020 | 10:12 AM
G37sPhoton's Avatar
G37sPhoton
similar issue on mine, as im working at home now, so don't drive it sufficiently or long enough etc and and it started to happen, a slower start after 3-4 days and then sometimes after 2 days of sitting..so took it on a long drive a few weekends ago and it was good for 4 days and then sat for 2 and slow crank again...finally one day, it got chilly here and went to start and dead...enter AAA and the guy jumped and said it was showing on his app 240cc or something like that , but battery is less than 3 years..everstart from wally world, so plant to take back and see if they will replace, if not going to Costco for theirs , but i recall, car sitting for 1+week when i traveled and no issues, but battery was oem at that time and or this one was newer etc...so maybe those factors and coolish weather , but good luck, as i thought maybe something was drawing current...the only thing i have done over summer was remove console to vinyl wrap, disconnect battery, so i thought maybe something is there and slowly drawing a slight charge..dont know if possible but, will replace battery and see if that fixes it...but may also invest in the tender gadget ...good luck dude
Old Jan 30, 2020 | 09:19 PM
beckb's Avatar
beckb
Originally Posted by heedtheninja67
Yes, once your car is started your alternator will charge the battery. You'll need at least 30 min if you needed a jump... I'd say more if it was completely dead (if you don't use a charger). Starting the car uses a lot of load. Like the previous post said, 30 sec is not enough time to determine voltage drop.
Thanks so much for your reply. The 100% dead battery has been fully charged & the car has been running just fine ever since. I appreciate your time & you sharing your knowledge with me!
gimmeshelter67
Jan 23, 2025 04:55 PM
PeterCollins
General Tech Questions
Jan 28, 2020 08:27 AM
Yashpatel21
Oct 28, 2014 03:49 PM
Foxtrot_01
Jan 31, 2013 03:59 PM
Italia311
Nov 6, 2012 10:35 PM
