Whining Noise Coming From the Engine on Cold Start
Old Dec 8, 2019 | 02:28 PM
droxia's Avatar
droxia
Hello everyone, I'm having a problem.
My car start to makes this whining noise on cold start also in cold weather, this noise goes away after the engine is warm up. A/C on or OFF doesn't change anything.
What is your opinion, and what should I troubleshoot first?
Thank you
Old Dec 9, 2019 | 02:29 PM
Surfnazi's Avatar
Surfnazi
Could it be bad alternator? Put a tester on it autozone and other part stores will check it for free with their battery load tester to see if the alternator is going bad
Old Dec 11, 2019 | 06:31 PM
droxia's Avatar
droxia
I did, they check the alternator it looks good, the battery needs to charge and the starter couldn't find on the machine he said. I also changed the belt didn't effect the noise, also just change the p.s fluid I will see the results tomorrow cold start.
Old Dec 12, 2019 | 05:42 AM
Surfnazi's Avatar
Surfnazi
Did you change tensioner pulley along with other pulleys
Old Dec 17, 2019 | 05:48 PM
droxia's Avatar
droxia
No, I didn't change any pulleys,
but the car also started to idle low on stop when it's on the gear. It drops down to 450 for a sec and goes back 500.
The normal idle is 650-690.
I cleaned the TB couple weeks ago. After hearing this noise.
I also have Stillen Gen 3.
Old Dec 27, 2019 | 01:29 PM
Surfnazi's Avatar
Surfnazi
Recheck vacuum lines on intake and that throttle body is squared down
Notfelix
Oct 8, 2019 10:26 AM
jplebeouf
General Tech Questions
36
Sep 5, 2018 08:32 PM
FiremanJ
82
Feb 9, 2018 11:48 AM
Jan 21, 2013 06:40 AM
brd_ptty
18
Mar 2, 2008 03:51 PM
