List Of G37x Fluids
Hey Guys, I recently got 2010 Infiniti G37x. I have been searching around the forum to get an accurate list of fluid types and capacities so I know WHAT and HOW MUCH to buy. I made this list so far.
Please add or edit with your knowledge suggest any recommended brands/Products!
Hopefully this helps new owners as well since information is all over the place.
Fuel Tank................................75L | 20galOil.........................................SAE 5W-30 | 5.2qt / 4.9L
Rear Differential Fluid................75W-90 | 1.4L
Automatic Transmission Fluid......Matic S ATF*3 | 6qt (Was suggested to use AMSoil Signature Series Fuel-Efficient Synthetic)
Power Steering Fluid……….…..…….Nissan PSF
Brake Fluid………………………..…......Super Heavy Duty Brake Fluid | DOT 3
Transfer Case Fluid……………....…..Type Matic J - Dexron VI
Cooling System AT…………..…...……8.5L | 50% Genuine Nissan (Blue) / 50% Distilled
You forgot the front diff.
Last time I did my fluids I used this: https://g35driver.com/forums/v36-diy...uid-drain.html
How much different are the G35s than the G37s
I know this is about the AWD, but related to the whole fluids thing...
The 6MT also has clutch fluid, supporting the hydraulics in the clutch master cylinder and the slave cylinder. It's the same fluid as the brake system, but there is a TSB from Nissan that you should be using the GTR Brake Fluid here.
