Help Intelligent Keys not working. Please advice.
Old Sep 21, 2018 | 08:57 PM
thechemist90's Avatar
thechemist90
Dear All,
New to the forum here and new G37 owner as well (picture of my 2011 G37x attached!). As the title of the thread says, my two fobs stopped working last Tuesday. I replaced the batteries on both and they still do not communicate with the car. I am able to start the car and drive it by inserting the fobs into the intelligent key port located to the left of the steering wheel. I can do so even when I remove the batteries from the fobs. My ‘intelligent key warning light’ is on before I start the engine and the car asks me to insert/remove the key accordingly. Proceeded by taking the car to the dealer to get the fobs reprogrammed, however, they told me they couldn’t even get on the system and suggested the problem is the BCM (which of course will cost $850 to replace).
I have looked into typical BCM malfunction symptoms and I haven’t noticed any of them. Bottom line, fobs aren’t able to communicate wirelessly with the car. Everything else seems to work accordingly.
Has anyone encountered a similar issue before?
Thanks in advance for your help!
Old Sep 22, 2018 | 12:05 AM
slartibartfast's Avatar
slartibartfast
Welcome.
I can't speak directly to your issue but will note that several folks have had to replace the BCM.
Old Sep 22, 2018 | 11:37 AM
thechemist90
Thank you for the response! Is there a specific reason why the BCM had to be replaced? Any other signs I could look for to confirm the issue? Thank you!
Old Sep 22, 2018 | 01:12 PM
13_SkylineSedan's Avatar
13_SkylineSedan
There is a separate module called the "Remote Keyless Entry Receiver" which likely has its own fuse. I can't actually find the circuit in my '13 manuals but it's likely powered through a fuse in the IPDM. If you can find that receiver (near the IPDM in '13), you could check it's connector for power and ground - should be +12 without the car running. Just an idea...
The BCM is like the CPU of all operations so that's why the dealer goes there. And if their Consult diagnostics rig can't communicate with all the car's black boxes, that may be the issue.
Trooper Orange
Nov 10, 2014 07:13 PM
Randjet
Apr 21, 2011 01:48 AM
hebguy03
Buying & Leasing
Feb 26, 2009 08:42 PM
bboysteele
Nov 14, 2007 06:55 PM
jadams
Aug 24, 2007 06:10 PM
