Knocking Sounds at take off
2011 G37S 60k miles
Been having a lot of knocking sounds when I start from a standstill.
e.g. Stopping at a light then when I apply gas it sounds like a diesel engine for 1 sec then it's fine. I use Premium gas so I know that's not the issue.
Bought one of those BlueDriver Bluetooth contraptions to see if I could pull a code and I am getting a U1000
U1000-01: CAN communication circuit : General Electrical Failure
Is that the CaM communication sensor? If it is where is that located? Front of the engine? I would assume there are 2 of them?
I would assume to take off the plug and clean the contacts to see if that fixes the issue.
If I need to replace them I would assume it's just a remove and replace?
Thanks in advance.
Thanks in advance.
CAN is the CANbus, the electronic backbone by which the sensors are read by the ECU.
Google is your friend
justinc7100
Apr 19, 2018 04:48 PM
marcelo19lp
24
Sep 22, 2010 01:05 AM
krayzrac3r
Site Feedback & Suggestions
Oct 9, 2008 11:24 AM
82chilam
Sep 17, 2008 07:21 AM
