Help best differential fluid? and tranny fluid?
Old May 16, 2018 | 01:05 AM
Meez403's Avatar
Meez403
Smile best differential fluid? and tranny fluid?
hey guys!
I'm going to be doing my differential and transmission fluids this weekend. I was just wondering if what would be the best fluids for these jobs?
I'm about to pull the trigger for either Castrol or Royal Purple 75W90 for diff fluid, and just use OEM fluid for transmission fluid.
Any other recommendations?
Thanks guys!
Old May 16, 2018 | 01:57 AM
slartibartfast's Avatar
slartibartfast
You forgot to ask which motor oil is the best. Your only real choice is traditional or full-synthetic? As long as it meets the SAE specs demanded by Infiniti, you're good to go.
Old May 16, 2018 | 05:42 AM
Surfnazi's Avatar
Surfnazi
Motul or Nissan fluid
Old May 16, 2018 | 06:02 AM
Lego_Maniac's Avatar
Lego_Maniac
I used Redline in the transmission, Motul in the differential.
Old May 16, 2018 | 09:06 AM
Baadnewsburr's Avatar
Baadnewsburr
I use Nissan in the tranny and Motul Pa90 in the rear diff and gear 300 synthetic in the front differential...what Motul do you guys use? I'm wondering if my use of Pa90 is out of date cause its been getting harder and harder to get locally and when i do find it its collecting dust on the shelf
Old May 16, 2018 | 05:17 PM
Meez403's Avatar
Meez403
Thanks for all the replies folks! I'll be buying some OEM tranny fluids and Motul differential oil!
Cheers,
Old May 17, 2018 | 06:09 AM
Surfnazi's Avatar
Surfnazi
Motul 75-90
Old May 17, 2018 | 12:12 PM
slartibartfast
I tell ya, this is no different than a "what's the best oil" thread. Ask ten people, you'll get five answers. They're all good as long as they meet Nissan's weight spec. Again, the only choice is synthetic or not.
Old May 17, 2018 | 10:24 PM
Meez403's Avatar
Meez403
Agreed!
Is there a huge differenxe between the Motul 75W-90 Gear 300 vs Motul 75W-90 Gear 300LS?
Old May 18, 2018 | 08:33 AM
Baadnewsburr
Originally Posted by Meez403
Agreed!
I think it depends on whether you have an "LS" if you don't probably no difference, if you do and your FD was noisy without the additives then probably yes
Old May 18, 2018 | 08:56 AM
Meez403's Avatar
Meez403
FD? Front Differential? I drive a 13' Infiniti G37 Coupe RWD IPL haha so I'm guessing I'll need the LS Motul then?
Old May 18, 2018 | 09:13 AM
Baadnewsburr
FD= Final drive. but yes if you have the IPL it should have an LSD and need the additive...
Old May 18, 2018 | 09:29 AM
Meez403's Avatar
Meez403
Thank you so much for all your replies!
Old May 18, 2018 | 10:27 AM
03Mach69Mach's Avatar
03Mach69Mach
Mobil 1 front & rear diffs. Valvoline Maxlife with Lubeguard platinum for transmission (three time drain & fill procedure). As stated, brands are a personal choice. BTW, the Maxlife has worked wonderfully in transmission and I currently have about 20,000 miles on changed fluid.
Old May 22, 2018 | 01:33 PM
Surfnazi's Avatar
Surfnazi
Never had bad experience with motul and this was on street and track cars. They also have great cs if you have issues
G37FTW
Aug 16, 2016 10:45 AM
ryang37x
Sep 22, 2015 05:33 AM
hollywhip
Aug 1, 2013 06:34 PM
Redvoodoo
Apr 8, 2011 02:16 PM
Budakai
28
Mar 24, 2009 06:25 AM
