trunk release problem
Old Jan 24, 2018 | 08:09 AM
Brian Londry's Avatar
Brian Londry
i have a 2009 G37X coupe. i cannot open my trunk in the conventional method. the intellegent key does not open it, the dash switch does not open it neither does the release button on the trunk. all 3 do nothing. i was however able to lower the back seat and use the release pull from inside the trunk to open it.
does anyone have an idea of how i can maybe fix this myself to get into my trunk?
Old Jan 24, 2018 | 09:30 AM
mitheralice's Avatar
mitheralice
When you open your trunk there is a cluster of wires hidden in a rubber tube between the front of the trunk and the main body of the car. Should look something like: https://g35driver.com/forums/attachm...ired-trunk.jpg
Typically after many uses the rubber gets soft and no longer protects the wires it's hiding. Chances are you have a severed wire somewhere in this region. I know the pain, my trunk light and trunk position sensor were severed on my own car.
Old Jan 24, 2018 | 09:36 AM
Brian Londry
thank you for the info. I will take a look later today after work and see if I can find a messed up wire
Brian
Old Jan 24, 2018 | 11:45 AM
telcoman's Avatar
telcoman
Have you checked the FSM?
Factory Service Manuals - NICO Club
See page PG-38
Telcoman
Old Jan 24, 2018 | 12:15 PM
Brian Londry
thank you for attaching it. I will check it out tonight.
Brian
Old Jan 24, 2018 | 09:45 PM
hurleyguys's Avatar
hurleyguys
in the glove box is there a switch there? if there is flip the switch.
i know in my old G35 i had a trunk lock out switch there for when you valet your car so they cant get into the trunk. i cant remember if there was a switch in my g37 or not. the switch was to the left of the main glove box compartment.
Old Jan 25, 2018 | 07:47 AM
Brian Londry
the switch is there and I did try it hoping for the "easy"fix, but that was not the problem. than for the help.
Brian
Old Jul 28, 2018 | 07:02 PM
2013's Avatar
2013
Brian
Im having same issue, you ever figure out what happened?
Old Jul 28, 2018 | 10:53 PM
13_SkylineSedan's Avatar
13_SkylineSedan
The power to the trunk actuator comes from the BCM. If none of the regular methods will open the trunk - key fob, dash switch, external switch - then you either have a failed actuator, a broken wire, or a confused BCM (not likely or other things wouldn't work).
The wires going through the rubber boot from the body to the trunk lid get bent or slightly twisted every time you open and close the trunk. You should be able to pull back that boot and check for broken or frayed wires. If everything looks fine there then it could be the actuator itself.
Hope that helps.
tite_tite
General Tech Questions
37
Feb 23, 2024 06:34 AM
RangerPivot
Feb 20, 2013 06:12 AM
Mid-Life Crisis
Jan 11, 2013 09:14 PM
afaa
Apr 14, 2010 09:39 PM
JKashat
18
Aug 28, 2009 02:51 AM
