Shifter doesn't always come out of park easily
The shifter on my G37x 2010 doesn't always come out of park on the first attempt. It sometimes takes a second try. Is it something to do with my timing on the brake pedal or shift button? Could it be something more serious?
If you are on any kind of incline while parking, set your parking brake before shifting to Park. I usually shift to Neutral, set the parking brake firmly, then shift to Park and take my foot off the brake. It may take some getting used to, but this is a habit I formed long ago and it works for me. It is similar to parking a MT in gear with the parking brake set.
The only time I've had problems is now and then, the release button won't click in to release and I have to squeeze it a couple of times before it takes. Other that that, typically it's because the output shaft is resting against the parking pawl.
I used to have a 13XS Sedan and i had the same exact issue. I had the car since new and it always had that problem. I had the car for 3 years and never bothered taking it in for the issue. But.... I did quickly learn that if i pressed the shift lock a certain way it worked every time. I would put my finger on the lower portion of the shift button and press it in. if i pressed it in the center or used 2 fingers to depress it it would lock up on me. That always led me to believe maybe it was a rigging issue on the button...
Same here. 2011 G37x Sedan. It always unlocks for me when I release and re-apply the brake pedal. I thought it was some kind of safety at first, but it doesn’t happen all the time now that I’m thinking about it. I guess we can chalk this up on the G’s quirks list too.
