Check engine like p2a00 sensor 1 bank 1
Old Apr 16, 2016 | 08:50 PM
F23jeff's Avatar
F23jeff
Hey guys I have a check engine light with the code p2a00.
Is this the driver or passenger mainstream? Also is there anything I should check before replacing the sensor?
Old Jul 18, 2016 | 02:36 PM
rothgar's Avatar
rothgar
Passenger side. Did you ever fix this? A year ago I had this code and replaced the sensor. That didn't help. A week ago I ended up taking it to a mechanic and he found a crack in the catalytic converter by doing a smoke test. It was replaced and I haven't had the code come back yet. The crack was located near the connection to the U-bracket that holds both cats underneath the car.
Old Jul 29, 2016 | 10:57 AM
SonicVQ's Avatar
SonicVQ
The passenger side (bank 1) A/F sensor is staying rich or lean longer than expected.
Possible causes:
• A/F sensor1
• A/F sensor 1 heater
• Heated oxygen sensor
• Fuel pressure
• Fuel injector
• Intake air leaks
• Exhaust gas leaks
Keep in mind the code is the SYMPTOM not the CAUSE. Sometimes they are the same, but not always.
Do you have a generic ODB scanner / ELM327 scanner?
If so you can look at your fuel trims and sensor 1 live data to figure out what the issue is.
If not, check for exhaust leaks from the exhaust manifold to past the rear O2 sensor.
Old Aug 16, 2016 | 04:48 PM
prov33n's Avatar
prov33n
Exhaust system
Have a muffler shop check for exhaust leaks. I had the same code and after chasing and replacing approximately 10 different parts, it was a stupid crack on the exhaust system.
If the tech doesn't use a stethoscope while hunting the leak, go to another shop. After literally spending 4 months chasing this code and resetting the CEL every 50 mi, fixing the exhaust leak fixed it.
Bottie
Jan 29, 2020 01:29 AM
Kris9884
General Tech Questions
Apr 20, 2016 09:08 AM
JBurch175
Apr 17, 2016 02:52 PM
JohnsG37x
Apr 15, 2016 03:45 PM
bwc
Apr 14, 2016 12:54 PM
