Whistling/howling noise when I reach highway speeds
Old Jun 17, 2015 | 12:15 AM
Slayer7435's Avatar
Slayer7435
09 G37x with 87k miles. Ever since i bought it used with 67k miles i heard a howling noise from the passenger side of the hood when i reach around 50-60 mph.
Old Jun 17, 2015 | 12:09 PM
Flakman's Avatar
Flakman
Yep. Common issue with the Gs. It's usually a torn/worn or dried seal somewhere. Depending on the issue, some have repaired the tear or lubed the seals to fix the problem. There are others that have not been able to find or fix. It's annoying, but very common.
Old Jun 17, 2015 | 07:22 PM
Slayer7435's Avatar
Slayer7435
Doesnt sound too bad. Thanks.
Old Jun 17, 2015 | 07:25 PM
Flakman's Avatar
Flakman
Typically just a nuisance. I haven't found the source of my whistling yet. Partially because I rarely don't have music playing, but it also only comes up at certain speeds and depends on wind direction. It's a PIA to locate.
Old Sep 18, 2015 | 11:40 PM
abretz89's Avatar
abretz89
Sorry for bumping an old thread but I had this same issue in my Z and low and behold it happened in the G I just bought. In both the Z and now the G the culprit is the rubber seal that goes around the tweeter on the inside and slips over the top corner of the side mirror outside. It can either get a slight tear where the mirror corner slips under or if the door panel was ever removed the seal might not be seated correctly. It's about a $30-40 part and I'd advise replacing it yourself since the dealer wanted 2.5 hours of labor and it can easily be done in the garage in 45 minutes if your familiar with removing the door panel. Hope this helps and if you need a picture of the piece I'm talking about let me know.
Old Sep 27, 2015 | 10:43 PM
fuzzed's Avatar
fuzzed
I have been chasing this noise for months, if you could please post or PM a photo I would greatly appreciate it.
Thanks,
Old Sep 27, 2015 | 10:54 PM
abretz89's Avatar
abretz89
No problem, I'll snap a couple pics tmrw and post em up. It's really surprising that something so small can make such a difference in cabin noise once you realize where it's coming from. It took me months of trial and error on the Z to find it because it's something most would have last on the list or never even look at.
Old Sep 28, 2015 | 09:09 AM
fuzzed's Avatar
fuzzed
That is what I am hoping, i have tried lots of "major" things which looked like they could be the culprit, hoping this is my issue. Thanks again.
Old Sep 29, 2015 | 08:58 PM
abretz89's Avatar
abretz89
Sorry for the delay but here are the photos of the typical cause for the wind noise in the cabin.
The tiny little tear seems to be caused by the adjusting up and down when the door opens over time wearing down the rubber and splitting it. That's where the air is entering the cabin and because it's so small you only hear it when at cruising speed when the pressure is the strongest and able to get thru the tear.
IIRC, the part cost about $40 when I bought one a couple years ago for my Z. It looks like the same exact part on the G and the replacement process is pretty easy. You just take off the interior door panel, the speaker cover and unbolt the side mirror assembly to free the rubber seal. The only tedious part is getting the new one in there perfectly since there's a little piece with 2 bumps that slip into holes where the window rolls down. Just takes a skinny flat head, a flashlight and some patience.
Attached Thumbnails Whistling/howling noise when I reach highway speeds-photo422.jpg   Whistling/howling noise when I reach highway speeds-photo946.jpg   Whistling/howling noise when I reach highway speeds-photo529.jpg   Whistling/howling noise when I reach highway speeds-photo392.jpg
Old Sep 30, 2015 | 10:54 AM
fuzzed's Avatar
fuzzed
Thanks for posting these. Unfortunately, mine seem to be in ok shape. I was hoping this was it. I will post once I eventually sort it out.
Thanks again.
Old Oct 30, 2015 | 01:42 PM
dondb's Avatar
dondb
1st post.....just purchased a G37 2010X and have a noise at highway speed, sounds like a bad window seal back door passenger side. When I get home from work I will look for the rip by the mirror. I will be following this thread for updates and post anything use full.
Old Nov 4, 2015 | 11:39 AM
dondb's Avatar
dondb
found the whistle.....rear passanger side fixed window has a loose seal. When we push on the glass it goes away. Sounds like the seals are really sensitive to rips cuts or wear?
eljoker
Future Models
19
May 30, 2022 11:48 AM
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
r0cketm0nkey
17
Nov 23, 2015 03:34 AM
cyberone28
Sep 23, 2015 01:56 PM
reachout
Sep 8, 2015 10:34 AM
