Heat/AC doesn't blow
Old Feb 28, 2015 | 10:41 PM
Used2BaHEMI's Avatar
Used2BaHEMI
Angry Heat/AC doesn't blow
Not sure what the deal is so I'm up for suggestions. My heater and ac no mater what the setting is will not blow air. It doesn't mater what the temp setting is or what the fan setting is the air never blows. PLEASE HELP.
Old Feb 28, 2015 | 10:47 PM
Perhaps the fan motor has gone out.
Old Mar 1, 2015 | 02:16 AM
RA081224's Avatar
RA081224
Its either a failed blower motor, blown fuse, failed HVAC control or bad wiring. Your going to need the wiring diagrams for your car and a multi-meter to figure much more out. My suggestion would be to trace down the fuse and check it. If that doesn't yield your problem, take it to a dealer or reputable mechanic unless you have the skills and equipment to carry the investigation further. The electrical system and body harness on the G are not trivial items to troubleshoot unless you know what your doing.
Old Mar 2, 2015 | 10:58 PM
Used2BaHEMI
I've done all I can from tracing the wire harness to fuses so mechanic it is! :-(
Old Mar 3, 2015 | 12:08 AM
RA081224's Avatar
RA081224
Good luck; hope its not something difficult to diagnose
parkern
Oct 1, 2015 10:15 PM
k19g37x
Sep 29, 2015 02:46 PM
cshawsg37
Sep 25, 2015 05:33 PM
