How can I fix the pull back motion when downshifting
Old Jan 25, 2015 | 10:29 PM
seansager's Avatar
seansager
I just bought an 09 G37xS, I noticed my car slings back when I let the car ride from 35mph to 25mph. And sometimes when I apply a heavy foot in the accel pedal trying to reach 40 mph, after letting it go it just bulls me back like Im applying brakes...
Old Jan 25, 2015 | 11:36 PM
vqsmile's Avatar
vqsmile
Can't tell exactly from your description, but it just sounds like what a high compression motor does in low gear. It is unclear if you're just experiencing the car's normal downshift, or if perhaps it isn't up shifting promptly. Are you in DS mode when this happens? Try manually selecting a higher gear and see if it doesn't change the braking effect you're feeling.
Old Jan 27, 2015 | 02:47 AM
HoldmyMouse's Avatar
HoldmyMouse
I think you are describing engine braking. Not sure how much it's pulling back for you but it should be normal when decelerating in DS mode.
Old Jan 27, 2015 | 10:10 AM
ram18962's Avatar
ram18962
Theres a TSB for harsh downshifting that is common. Possible your car may not have had it done and should fix the problem. I had the same issue.
Chris Olson
Dec 29, 2025 07:59 PM
superjoey
31
Mar 22, 2023 11:56 PM
Grayg37s
Sep 27, 2015 03:12 PM
bikerjosh
Aug 19, 2015 11:26 PM
