Headlight - Left Front (HID) Problem G37 Sedan
Old Sep 12, 2014 | 09:52 PM
andy404's Avatar
andy404
Hey all,
I've got a 2009 Infiniti G37 Blue Slate Sedan. Recenly, I eclipsed the ever so infamous 60k mile mark. Lucky me, it was only after this point a comedic series of things started to go wrong with my car: the light behind my clock went out, the instrument cluster backlight failed, the brakes need repairing, all of my tires appear bald (only kidding, that's my fault). I took my car in today because I noticed the left front headlight would not power on at night. I performed a small amount of troubleshooting (turn the lights on and off several times) and eventually the light would flicker, then slowly a charge would build and the light would eventually come on. However, that was two weeks ago and now I am to the point now where that no longer works effectively. The dealership and they quoted me a whole new light assembly (go figure) with labor for $1,500. They claim the only issue is that the ballast in this headlight is not working correctly and sometimes may not produce a charge and that the headlight is perfectly fine.
I'm curious, can't I take this to an import shop and have them just replace the ballast? The part online is relatively inexpensive. The dealership claims you must replace the entire assembly, but my gut tells me otherwise. Anyone else have this problem? Any advice on the issue is much appreciated!
P.S. This month was also my last car payment
Old Sep 13, 2014 | 07:28 AM
telcoman's Avatar
telcoman
Originally Posted by andy404
Hey all,
Try replacing it yourself
https://www.myg37.com/forums/d-i-y-i...placement.html
Telcoman
Old Sep 17, 2014 | 06:43 AM
thedonjp's Avatar
thedonjp
Yes you can take it to a tuner shop. Have them to look it over before buying anything unless you know for sure it's the issue.
Old Sep 30, 2014 | 10:59 PM
bmy986's Avatar
bmy986
If you haven't done this yet look at HID Ballast Replacement thread i started. Its pretty straight-forward.
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
Spicy_Kimchee
Aug 11, 2015 09:10 AM
dAgent
21
Aug 6, 2015 02:15 PM
