g37 sedan automatic in limp mode
Old Mar 2, 2014 | 07:04 PM
09G39Sedan's Avatar
09G39Sedan
2009 G37 automatic....have a code P1608. Vehicle runs good then will go into limp mode. Clear code and car will run fine again. 20 miles or less limp mode comes back. Somethings wrong with the vvel system. Problem is I cant find any repair information about this code, other then a horrible trouble tree on mitchell which has led me to a end telling me to replace both vvel sub actuator motors( I haven't replaced anything yet). Vehicle has been to a few shops before landing in mine....Anyone have any advice or have seen this problem with their vehicle? Any info would be appreciated since I cant find any R&R information or labor times on this system. (this is probably why the other shops dont want to mess with it)
Old Mar 3, 2014 | 09:46 AM
RISKY GUY's Avatar
RISKY GUY
I'm almost positive the vvel assembly is one part that can't just be changed.
I'd do some research on just the vvel portion, so you know how it works.
www.autozine.org
Look under engines, will list anything that is made in a production vehicle.
This should explain what you need.
Old Jul 16, 2022 | 05:54 PM
Battl1ngB1atch's Avatar
Battl1ngB1atch
Know this is an old thread but did you manage to fix it? Having the same issue
onealrk
May 29, 2023 02:15 PM
RaisinBran210
Oct 21, 2020 02:32 PM
SamL11B
Jul 6, 2019 07:21 PM
ill12will8
Oct 26, 2015 10:09 PM
