Help Broken door lock button? locks don't work on shutoff?
Old Jul 4, 2012 | 08:55 PM
Diode Dynamics's Avatar
Diode Dynamics
Hey guys,
I'm Paul at DD, but I personally also drive an 09 auto G37x.
I've been having such random issues for past two weeks. My heated seat got flipped on and burned a 2" hole in my seat. Dealership sent that to Infiniti to decide on warranty. My front and rear cupholders also broke the same week (seems to be a common issue).
Right when I got the car back from two days of them looking at it, I was getting out of the car and hit the unlock button. I guess I got in the habit of doing it so I could start opening the door as I turned off the engine. I don't like wasting time!
But this time I did it right as I shut off the car, and nothing happened... Doors didn't unlock at all. I thought it was like what happens when you unlock as someone is pulling the handle, but nope- I tried again and nothing happened. I took a closer look and the button had popped out. Tried popping it in but it is broken, both sides have a crack in the plastic.
Now my doors no longer automatically unlock when I get out, and the button doesn't work at all. It's really frustrating because when I use the tab by the handle to manually unlock, the car gets all confused and beeps like crazy every time I get out or in. And I have to reach over to let someone in the car if I'm picking them up with the car running. The only current remedy is using my keyfob to unlock the door as well as the system/computer. The proximity button still works fine on the outside of the door.
As soon as I hear back about my seat I'll take it in, I would think this should be covered by warranty.
Just wanting to know if anyone has experienced this before, and what happened.
Paul
Old Jul 5, 2012 | 11:57 PM
Diode Dynamics
If the passenger presses their unlock button with the vehicle in park, it quickly unlocks and locks again.
Old Jul 6, 2012 | 11:14 AM
DeamonG37s's Avatar
DeamonG37s
we have cup holders in front? but if u got warrenty send it to them.
Old Jul 6, 2012 | 11:25 AM
Rad_Slinger's Avatar
Rad_Slinger
Sounds like you may have a short in either the lock button, or the button on the outside handle. A,most the same thing happened to my maxima. They ended up changing out the handle buttons and the drivers door control panel.
Whatever, it never happened after that. They said sometimes moisture can get down into there and corrode the connections so the connection "shorts itself". Literally, my doors would lock and unlock by themselves like the car was possessed.
warpeacelove
Oct 28, 2015 02:59 AM
STownSaint
Aug 29, 2015 09:04 AM
JohnsG37x
Aug 2, 2015 07:33 AM
Skeletor06
Aug 2, 2015 12:54 AM
