Opinions on Oil Change
Old Apr 16, 2012 | 03:35 PM
Stevew999's Avatar
Stevew999
New G owner here and just wondering what the conventional thinking is regarding on oil change service: dealer's service department or one of the standard speedy places?
I just got the car and have not dealt with Infiniti as a service provider so any words of wisdom would be greatly appreciated.
I have considered DIY and probably will at some point but to start I want everything done as per standard specs.
Thanks, Steve.
Old Apr 16, 2012 | 04:52 PM
MrBig's Avatar
MrBig
I would go to Infiniti or Nissan if you don't DIY. Most people put in synthetic, that can get pricy at the dealer. Sometimes you can save a few $$$ if you bring in your own oil.
Old Apr 16, 2012 | 05:22 PM
Stevew999's Avatar
Stevew999
Thanks- I appreciate the insight.
Old Apr 16, 2012 | 05:33 PM
Sunny's G37's Avatar
Sunny's G37
Good idea to get it done at the dealership. Doesn't cost much anyways. Plus you can trust people who are trained precisely for your car (although there are exceptions).
On the flip side, check this out.
https://www.myg37.com/forums/engine-...otsa-pics.html
Each can decide which route to go with and what to trust
Congrats on the new car !!
Old Apr 16, 2012 | 06:17 PM
Stevew999's Avatar
Stevew999
Thank you- great info. I'm VERY happy with the car. I have had my eye on one of these for a long time and was very close to an '08 TL then happened upon this one. Way more car than the Acura.
Taking this one in Friday to have the exhaust replaced (due to the infamous rattle), have them look at the steering wheel bezel scratches as well as some cracks forming in the driver's seat. I just called the dealer today and he told me to plan on an hour or so for the muffler issue. I was expecting some kind of pushback but he said he would do a replacement without even hearing the noise. I thought that was quite impressive as I was expecting them to want to hear it, then plan a remediation.
Not sure how far I will get with the steering wheel and seat but it's worth a try.
I am also doing some research on my paint. It's black so it has swirls but there are some very strange little 'dots' (for lack of a better description) on the surface of the hood. I hadn't noticed them until about my 2nd wash. I am going to clay, then polish with the PC 7424XP and hope all is well in the end but I'm also going to ask about this when I go back to the dealer.
Old Apr 18, 2012 | 03:29 PM
ANMVQ's Avatar
ANMVQ
Yea I used Synthetic -mobil 1-every 2500 like clock work at the dealer. 63$ well spent.
Old Apr 18, 2012 | 04:30 PM
rlo's Avatar
rlo
I am going to say what everyone is saying in reverse.
Anywhere except a franchised speedy oil place.
Old Apr 18, 2012 | 04:49 PM
cruzmisl's Avatar
cruzmisl
It might have been repainted at some point. You can tell if there isn't any stock "orange peel" on those areas and it is mostly flat. Stock orange peel is very easy to spot on black in the shade (if the car is decently clean).
I basically had my entire passenger side repainted when someone's window blew up on my car as they were passing me on the right on the freeway.
As for oil changes, the worst part is removing the air deflector/shield to get access to the oil filter & drain. It isn't like honda where you have a beam or something in the way that causes oil to splash everywhere.
Get some race ramps, buy some Mobile-1 at costco or walmart, and save yourself some money!
Old Apr 19, 2012 | 01:44 AM
TVPostSound's Avatar
TVPostSound
You DO NOT have to remove the shield, just remove the 5 rear bolts, and fold the flap forward!!
Old May 6, 2012 | 09:49 PM
brainpa's Avatar
brainpa
"I just called the dealer today and he told me to plan on an hour or so for the muffler issue. I was expecting some kind of pushback but he said he would do a replacement without even hearing the noise. "
That's cause there is a TSB out for it... I had it done as well.
I use the dealership and buy and bring in my own Royal Purple.
2012G37
Intake and Exhaust
43
Jun 12, 2024 10:35 PM
Victory
17
Oct 27, 2022 03:45 PM
peterso2
Mar 25, 2019 11:28 AM
sharmelan
17
Sep 14, 2015 03:18 PM
