Help i saw some errors after scaning ECM for G37
Old Apr 7, 2012 | 04:30 AM
the dreame's Avatar
the dreame
Dears
i have a problem on my parking sensors, it give continuos sound when i enable it i think one of the sensor hang or damaged. i went to a shop to scan my ECM and found some errors P1212, U1001, U0101 and U1000. i reset it but its keeps coming.
what u think the problem with this errors and how to reset it
how can i know which parking sensor is affected
my car is G37 sedan 2009 journey. it is working fine with battery issue or CEL.
Old Apr 14, 2012 | 12:08 AM
the dreame's Avatar
the dreame
any ideas
Old Apr 22, 2012 | 06:56 PM
TVPostSound's Avatar
TVPostSound
Originally Posted by the dreame
Dears
Those codes are all CAN communications issues.
Either the ECM is toast, or you cut some wires, or a connector loose.
Old Apr 25, 2012 | 06:23 AM
the dreame's Avatar
the dreame
Thanks for replaying
how to solve this issue. i didn't touch any wiring of my car
Old Apr 28, 2012 | 11:09 AM
TVPostSound
Is this a US spec car?
If it's not replace any LED bulbs you have upgraded, back to stock.
Disconnect any HID replacement, and return to stock.
Then scan, and see if the codes disappear.
If this works, Ill then explain.
Old May 2, 2012 | 06:13 AM
the dreame's Avatar
the dreame
it is not US Spec.
i installed LED bulbs on license plate lights and all of interior of my G37 also i have original HID only.
Old Aug 10, 2019 | 08:00 AM
Rueben Limes's Avatar
Rueben Limes
If your still on here I would like to know why disconnect all the leds back to
Why change the led back to stock? What will it do?
Old Aug 10, 2019 | 10:03 AM
telcoman's Avatar
telcoman
Restore the correct/proper voltages, signals, and wave forms that the ECM is programmed to look for..
Read the FSM
Old Aug 10, 2019 | 10:28 AM
Rueben Limes
Read the FSM
Ok I understand completely thanks this was so much help!👍🏾 As I’m having a issue with the fuse blowing and it didn’t happen until I changed my battery. Codes p010c and u0101 after a water pump was changed but my battery went bad at the same time I checked all the grounds but no check engine light yet but codes are stored.
Old Aug 10, 2019 | 03:34 PM
slartibartfast's Avatar
slartibartfast
Oh my god. Why does it smell like death in here?
ThebigJ
Aug 25, 2015 09:22 PM
Zach Stewart
Aug 18, 2015 05:01 PM
Ali K.
Aug 5, 2015 11:49 PM
