Help Windshield Washers?
Old Aug 20, 2011 | 09:49 PM
dpattana's Avatar
dpattana
Windshield Washers?
Wanted some insight before I take the car to the dealer. I've got a 2011 G37s sedan and I recently discovered that the windshield washers are not working. I checked to see if there was windshield washer fluid and there is and I also checked to see if the nozzles are clogged and they aren't. I do here that the pump is working but nothing is being sprayed out. Any ideas on what else to check.
Old Aug 22, 2011 | 08:12 AM
KLB's Avatar
KLB
Could be a hose disconnected. Is there washer fluid on the ground under the car when you try to use it?
Old Aug 22, 2011 | 09:03 AM
dpattana's Avatar
dpattana
No water under the car.
Old Sep 9, 2011 | 01:26 AM
Fezzik's Avatar
Fezzik
Check it out under warranty. If dirt got in the fluid it can stop up the line
Gefartenblatz
Nov 10, 2015 11:45 AM
2K1 6T8
Oct 6, 2015 07:40 PM
Wreckreation
Sep 21, 2015 06:27 PM
gnawhdivad
Sep 18, 2015 07:02 PM
G10
Sep 17, 2015 11:42 AM
