WTB good brake bleeder kit
Old Oct 24, 2010 | 08:10 PM
wakeboardr116's Avatar
wakeboardr116
So I've been bleeding my brakes the cheap and slow way by just using an empty water bottle and having my friend pump the brakes. I've decided its time to invest in something that I can use my self. Does anyone have a good power bleeder they recomend or have used before? I'd like something that I can use by myself fairly easily.
Old Oct 24, 2010 | 10:04 PM
Speedbleeder.com
Old Oct 24, 2010 | 10:25 PM
wakeboardr116
Thanks I've seen those before but forgot about them. Have you used them before, is there any chance they leak? Now that I've been tracking quite a bit I change the fluid a lot more often and don't want to risk something leaking. I'm still considering something that I can pressurize the system with to make sure it is 100% air free. Maybe something I can use along with the speedbleeders.
Old Oct 24, 2010 | 10:31 PM
I use them. They don't leak. Something to bleed using pressure is going to be a lot more expensive.
Old Oct 24, 2010 | 10:40 PM
wakeboardr116
Yeah I realize they cost more and I'm willing to spend some money for one. Nothing too crazy though. I plan on doing a lot more tracking next season so I want something that works well and will last.
I'll probably go ahead and order some speedbleeders for now and see how well they work, then come spring time maybe start looking into a pressure bleeder.
wakeboardr116
Do you remember what size you got for the speedbleeders?
Old Oct 27, 2010 | 05:17 PM
D_Nyholm's Avatar
D_Nyholm
I use a Motive Power Bleeder. You just have to make sure that you get the right cap for the Infiniti. I have one and I can use it on two of my cars with the same cap, but haven't tried it on the Infiniti yet.
Old Oct 27, 2010 | 05:22 PM
wakeboardr116
Do you have a link to the one you use or where you bought it from?
Old Oct 27, 2010 | 09:05 PM
D_Nyholm's Avatar
D_Nyholm
Here is the website:
StoreFront -- Motive Products Online Store
You can probably get it cheaper by searching around on the net. Even Amazon.com has them. They are pretty well known and if you plan on using it a lot, spend a couple extra bucks and get the black version since it has more metal parts.
Old Oct 27, 2010 | 11:17 PM
wakeboardr116
Thanks. Do you know which adapter size fits the G?
Old Oct 28, 2010 | 10:17 AM
soundmike's Avatar
soundmike
It's the same as far as i can tell. I've used mine on both the G and the other two Nissan's in the pack.
I really like this bleeder, makes bleeding so much easier. You do end up using more fluid than necessary.
Old Oct 28, 2010 | 10:43 AM
wakeboardr116
Which bleeder and adapter did you get?
Old Oct 28, 2010 | 02:51 PM
soundmike's Avatar
soundmike
Part 0107 IIRC, i have a mini-review here.
Old Oct 28, 2010 | 02:54 PM
wakeboardr116
Thanks. I just called them and asked and that was the same number they told me so that should be right.
Old Nov 13, 2010 | 11:50 PM
bsowhat1's Avatar
bsowhat1
The Motive bleeder works really well when there is a specific fitting master cylinder cap available. The Ford cap 0107 works well. I'm not a fan of their universal cap. It tends to leak.
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
filipinowise
Intake and Exhaust
Sep 24, 2015 04:18 PM
TheLocNar
Aug 16, 2015 07:14 PM
connoisseurr
Aug 16, 2015 04:26 PM
