Limp Windshield Washers
Old Feb 2, 2010 | 12:02 PM
madmax2k1's Avatar
madmax2k1
I had the same issue with the right-side nozzle, I just used a pin to clean it, and it's back to normal now (the sprayer that is)
Old Feb 4, 2010 | 11:54 PM
Pip's Avatar
Pip
Originally Posted by G Nack 37s
on my driverside i have the top one spraying to hard that it goes over my roof.
Use it for tailgaters. Either that or pop open the moon roof and hawk a lugie that lands on their windshield.
Old Feb 5, 2010 | 12:00 AM
Pip's Avatar
Pip
Sooooooo, have any of you tried cleaning out the jets yet?
I had to take the vehicle in to the dealer for the Mass Air Flow sensor TSB and they fixed the sprayers too while it was there.
Old Mar 19, 2019 | 11:32 PM
Infinibini's Avatar
Infinibini
I didn't know the sprayers were supposed to be functional. Since I got the car, each sprayer only has one thin stream that shoots right over the top of the car. I have to tap the sprayer switch forward so it motor barely goes, in hopes that a few drops get on my windshield before the stream shoots over the car (all the way over onto the ground behind the trunk).
Old Mar 21, 2019 | 02:30 AM
13_SkylineSedan's Avatar
13_SkylineSedan
Holy Zombie Thread Batman. Hey the washer nozzle's aim is adjustable. The book says it takes a special tool and that you should "never use a needle or small pin". It then goes on to say that if there is wax or dust in the nozzle you should "clear it using a needle or small pin"...
Old Mar 22, 2019 | 01:49 PM
Infinibini's Avatar
Infinibini
Hello and welcome to the zombie thread.
I used a pin to poke my sprayer holes, I honestly never knew there were three per side. Now they work great, it's amazing! Three solid streams on each side, aiming right at the center of the windshield.
ill12will8
Oct 26, 2015 10:09 PM
2K1 6T8
Oct 6, 2015 07:40 PM
gnawhdivad
Sep 18, 2015 07:02 PM
G10
Sep 17, 2015 11:42 AM
