suspension questions....
Old Dec 18, 2009 | 04:55 PM
gicode0823's Avatar
gicode0823
is there any easier way to take out the front suspension rather then pushing rotor down hard enough to pull them out?
I remember it took me forever to get my front suspension out I don't know what I was doing wrong ...
any suggestion?
Old Dec 18, 2009 | 06:45 PM
jarborn1's Avatar
jarborn1
Using a compressor?
That post sounds pretty scary man..
Old Dec 18, 2009 | 07:10 PM
gicode0823's Avatar
gicode0823
so you compress the spring and follow the DIY posted here?
I thought u compress the spring after taking the whole suspension out?
Old Dec 18, 2009 | 07:17 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
are you talking about taking out just the springs, or the whole suspension. Because you said "front suspension"
Old Dec 18, 2009 | 07:22 PM
gicode0823's Avatar
gicode0823
suspension
Old Dec 18, 2009 | 07:46 PM
wakeboardr116's Avatar
wakeboardr116
Compress the springs first.
Old Dec 18, 2009 | 08:51 PM
gicode0823's Avatar
gicode0823
oh I didnt know lol I must be real noob
if you look at DIY here on myg37, he didnt compress the spring first
Old Dec 18, 2009 | 09:00 PM
I don't know how you didn't decapitate yourself. You always compress the springs before removing them, at least the fronts. There is a lot of energy in those compressed springs. What are you installing?
Old Dec 18, 2009 | 09:33 PM
STOOF's Avatar
STOOF
Guys im pretty sure hes talking about taking the front suspension out of the car, not taking the springs off the struts.
Did you unbolt the black bracket that holds the bottom of the strut? Then you pull the end link out from the strut.
After that and the top 3 nuts it should just come right out. You shouldnt have to push the rotor/A arm down at all
Old Dec 18, 2009 | 10:40 PM
gicode0823's Avatar
gicode0823
yeah I took the bracket off and took the bolt on bottom suspension bolt
but it was impossible to remove the front suspension (spring and strut together)
Old Dec 18, 2009 | 10:42 PM
gicode0823's Avatar
gicode0823
I have to install some coilover =D
when I was installing eibach it was pain in my butt to remove front suspension... almost impossible to remove them...
Old Dec 21, 2009 | 10:17 AM
gicode0823's Avatar
gicode0823
hmm so
1: take the wheels off
2: lose the bolts on tower
3: take the 4 bolts on the bottom part of the suspension
4: compress the spring while its mounted
5: take out the whole suspension
I looked at some of the DIY (not for G) but i didnt see people compress their spring before taking it out...
Im confused ..
Old Dec 21, 2009 | 10:37 AM
wakeboardr116
I miss understood you earlier. Do not compress the srping before you take the entire setup out.
Old Dec 21, 2009 | 10:59 AM
GiGGaplease's Avatar
GiGGaplease
would it make things easier if i loosen the three bolts on top of the tower? i tried doing the 4 bolts at the bottom but those bastards wouldnt move. going to see later how much its going to be to install springs for the front.
Old Dec 21, 2009 | 03:56 PM
gicode0823's Avatar
gicode0823
so what's the proper step to take out the front "set up" ?
I had hard time uninstalling them last time I tried to install spring
