Programming TPMS yourself
Old Mar 16, 2009 | 12:42 PM
  #31
SkylineV36's Avatar
SkylineV36
I am changing over to Volks shortly, on the front wheel hub there was small metal bracket on each side. Is this part of the tpms system? Do I still need them on for my tpms to work with my new volks that have the oem sensors already installed? Thanks.
Originally Posted by Blackjack
Something happened with mine when I got my Volks on and the dealer charged $100 to resync them.
Ideally you shouldn't have problems, but it happens.
Old Apr 5, 2009 | 08:39 PM
  #32
Oggie's Avatar
Oggie
I have two sets of factory rims and both sets have TPMS. How many sets of wheels would the car be able to retain? Just one set or the car can handle more? Does anyone know?
Old Apr 5, 2009 | 09:00 PM
  #33
WhosUrBuddiee's Avatar
WhosUrBuddiee
not really! the dealer around here charges $150 for programming if you have aftermarket wheels.
Holy crap you are being ripped. The dealership by my house said it was 35 dollars to reset sensors for after market rims.
Old Apr 5, 2009 | 09:16 PM
  #34
STOOF's Avatar
STOOF
im pretty sure it only retains one set at a time.
Old Apr 23, 2009 | 01:24 PM
  #35
lmulion03's Avatar
lmulion03
I got quoted 39 to re-sync sensors at Glendale Infiniti.
Old Apr 30, 2009 | 02:25 PM
  #36
lmulion03's Avatar
lmulion03
I swapped my tire sensors from my old stock (08 G35 Journey Sedan) to my new g37 sport wheels. I asked the dealership if they had to resync, and they said no - it should do it automatically. There was no light indicating that it wasn't working. I was thinking I was going to pay, but I guess not!
Old May 4, 2009 | 09:06 AM
  #37
MaxdOut's Avatar
MaxdOut
I think the AutoEnginuity with Nissan/Infiniti enhancement should be able to set the TPMS, but it is $350 for both.
Looking into picking this up myself but need to make sure that it is updated for 09 models.
Old Jun 27, 2009 | 01:30 PM
  #38
SANTOS29's Avatar
SANTOS29
I'm in the same boat right now, will the OTC one work?, at this time I'm willing to buy the tool since I'll be running winter and summer setup, and is pointless for me to go to the dealer everytime I need to change rims.
Old Jun 27, 2009 | 03:36 PM
  #39
IvoryG's Avatar
IvoryG
No unfortunately you have to have the consult 3 also.
Old Jun 27, 2009 | 03:53 PM
  #40
akuma_83's Avatar
akuma_83
Or you could just save your money and not go through all of the hassle and just drive the car and ignore the (!) light... but for those of you guys that get it done free are lucky, unlike some of us that get ripped off at the STEALERship!
Old Jun 27, 2009 | 05:38 PM
  #41
07BlackG35Stud's Avatar
07BlackG35Stud
Guys guys guys....if you're retaining the same sensors and putting them on your aftermarket wheels, there is no reprogramming necessary. Just take the car for a drive and after a few miles it will resync will all 4 sensors and the light will go off. Make sure all tires have at least 32psi (I think this is the min before it sets the light off) or more, and you should be good to go.
Also, the car only retains 1 set at a time, which is why if you swap them from OEM wheels to aftermarket wheels, there is no reprogramming involved - I guess some dealers out there are taking advantage of the naive and charging for not doing anything.
By the way, even when I actually changed sensors (twice in the past), my dealer reprogrammed them for free. It takes them 5 minutes!
Old Jun 28, 2009 | 11:52 AM
  #42
SANTOS29's Avatar
SANTOS29
I'm not using the same sensors for my summer setup, also here in Calgary we only have 1 dealer so they can name any price they feel like, right now as it stands each rim set has their own TPMS sensor, , I'm still not sure why OTC will sell a tool that claims to reset the TPMS system if I still need the Consult III
Old Jun 28, 2009 | 12:33 PM
  #43
IvoryG's Avatar
IvoryG
From everything I could find the OTC tool will active the sensors but you need the consult III to tell the car to look for them.
Old May 8, 2014 | 12:06 PM
  #44
d088's Avatar
d088
Here is a great write up on how to test and re-sync your TPMS. Loom about midway down the page for a post by "Mustang5L5"
tpms re-learning pressure sensor ID with no special tools - Page 2 - G35Driver
I didn't bother with the tool he mentions. I just used a regular old indoor single-pole light switch (99 cents) with a wire coming off one side of the switch grounded to the firewall and a wire coming off the other side jammed into the TPMS connector under the dash. Worked like a charm!
jgronline
Sep 21, 2015 08:44 PM
JG_G37
Sep 19, 2015 09:07 PM
Thirty_Seven
Sep 18, 2015 11:34 PM
Detailed Image
Lighting/Cleaning Products
Sep 18, 2015 03:39 PM
Detailed Image
Sep 16, 2015 08:54 AM
