Question on what the ECU reset will do..
Old Feb 7, 2008 | 04:25 PM
RedlineSi's Avatar
RedlineSi
My TPMS has been on since I got the car. I haven't had time to take it in yet, but when I picked up my plates, they said they would just have to reset it by hooking it up to a laptop. They were about to close at the time so I had to come in another time.
Anyways, does anyone know if the ECU reset trick will take off the damn TPMS light.?
Old Feb 7, 2008 | 04:48 PM
DiamondGCoupe's Avatar
DiamondGCoupe
Should, why don't you check your tire pressure.. Unless its faulty your tires might be low (<26psi I think the light comes on?) ECU reset should take care of the problem but if your tires are low or the sensor is faulty it will come back on with 50 miles after driving.
Old Feb 7, 2008 | 05:24 PM
RedlineSi's Avatar
RedlineSi
I've checked them many times, as did the dealer. The light is always on, never goes off, doesn't blink, nothing.
Old Feb 7, 2008 | 05:46 PM
DiamondGCoupe
I thought you said you haven't had time to take it in yet? Well either way, you need to tell them to check your sensors and replace them if necessary. Try an ECU reset, sure can't hurt. Probably will solve the light problem temporarily but that's all I can promise.. It will automatically come back on once you start driving for a while. Maybe there is a fuse (doubt it, but maybe) that you could pull in the mean time.
Old Feb 7, 2008 | 07:07 PM
RedlineSi's Avatar
RedlineSi
When I went in to get my plates, they checked the tires, but they were closing so they couldn't reset it then. I've been out of town for business and haven't got back in. I did the ECU reset, and got it to work, but the light never changed! Oh well, I'll take it in next week. My dealership just has such **** hours. M-F 7-5.
Old Feb 7, 2008 | 10:09 PM
DiamondGCoupe
Ah that's how they all are unfortunately. The Lexus dealer down here is actually open til 10 I think for service. They sell a hundred cars a week though so I suppose they have a reason to be open late.
Old Feb 9, 2008 | 07:04 PM
sculhane's Avatar
sculhane
I had the same issue. When I picked up the car (with winter tires on), the TPMS light came on after about 20 minutes. I went straight back to the dealer and they recalibrated the sensors. Took about 1.5 hours and all is good since then.
Raleclair
Oct 8, 2015 02:06 PM
Detailed Image
Lighting/Cleaning Products
Sep 11, 2015 08:33 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
harlemcat45
Sep 9, 2015 09:35 AM
