Rearview Window Power
Old Sep 3, 2007 | 10:48 PM
bolaber's Avatar
bolaber
Hi guys,
Does anyone know what the difference between the three cables on the rearview mirror?
I know there is a black, green and a brown cable.
Which is ground? Which is the 12v?
Old Sep 3, 2007 | 11:19 PM
Memphoman's Avatar
Memphoman
is that a 10 pin connector?
Old Sep 3, 2007 | 11:32 PM
bolaber's Avatar
bolaber
i realyl have no idea...
Old Sep 3, 2007 | 11:41 PM
Memphoman's Avatar
Memphoman
BAT is pin 10 and gr wire, assuming ground is black, but, best if U check with a meter to be sure. Using invisicord for a detector? With plug disconnected, 10 little rectangles and 3 wires, brown, green and black?
Old Sep 4, 2007 | 12:09 AM
bolaber's Avatar
bolaber
i checked.. it seeemed to be 22 pin with brown , green and black
Old Sep 4, 2007 | 01:09 AM
bolaber's Avatar
bolaber
btw.. yes.. its for invisicord
Old Sep 4, 2007 | 01:12 AM
bolaber's Avatar
bolaber
if i had to guess the brown would be the 12v and the black would be the ground.. but i dont want to take any chances..
Old Sep 4, 2007 | 11:43 AM
Memphoman's Avatar
Memphoman
22 pin at the mirror itself? manual shows it to be R3 connector, 10 pin, and BAT on the gr wire, brown is ignition and black being ground.
Old Oct 5, 2007 | 03:34 PM
marsb007's Avatar
marsb007
brown is switched 12v, green is always on 12v, black is ground
Old Oct 5, 2007 | 04:14 PM
RedHerring's Avatar
RedHerring
Yes, brown switched 12v and Black is ground. I know this for sure, because I just installed my invisicord.
Old Oct 5, 2007 | 06:04 PM
ABQG35c's Avatar
ABQG35c
Voltmeter FTW
Old Oct 29, 2007 | 11:42 PM
PDorian's Avatar
PDorian
How difficult was it to gain access to the wires in back of the rearview mirror?
Old Oct 30, 2007 | 08:20 AM
bostonmerlin's Avatar
bostonmerlin
check out this thread.. good stuff.
https://www.myg37.com/forums/showthr...radar+detector
Old Oct 30, 2007 | 08:38 AM
RedHerring's Avatar
RedHerring
Real men don't need voltmeters, we use our tongues.
Plug is easy to unplug, flip mirror down, push tab on connector, pull out. Black is ground, brown is switched +12. The G37 connector is harder to get the invisicord pins to insert, try all 4 sides of the square hole. My GND went in the bottom side, the +12v went in from the side-side, or top, can't remember.
vamarris
Dec 9, 2018 11:10 AM
RexHavoc
Oct 2, 2015 11:47 AM
Awgd8
Sep 30, 2015 06:22 PM
MrRiv
Sep 29, 2015 04:59 PM
mikysee
Sep 28, 2015 11:18 AM
