Upcoming Timing Job
Old Dec 10, 2025 | 12:37 AM
AMP_01's Avatar
AMP_01
Upcoming Timing Job
Hi all! I have a big job coming up this spring (winter weather is HORRIBLE) and timing chains are a part of it (yay water pump failure). I read in the fsm that we need the flywheel holder tool to remove the crank pulley, and seeing online that I'd be spending roughly 150 plus shipping to remove it. Are there any other ways to remove/reinstall the crank pulley? I am on a 6MT if that makes a difference.
Any individual experience on replacing the secondary chains would help too as there isn't much info on them.
The work will consist of brake caliper rebuilds, hardline rear brake line replacements, hardline fuel and hardline evap lines replacements, rear diff bushings + subframe collars and diff brace, water pump, gallery gaskets, all chains, tensioners and guides, stillen Gen 3's, and ISR LTH.
Throwing myself into a massive project with 5.25 days to finish it in late March/early April so as much info as I can gather the better! Appreciate all the help!
g37x_coupe
Apr 23, 2022 11:11 PM
pja2121
Apr 14, 2020 02:12 PM
G37_Zero.exe
May 19, 2018 10:59 PM
WRX_to_G37
Oct 2, 2011 09:15 PM
Nap
May 30, 2011 03:39 AM
