2011 G37x Sedan – Cylinder Misfire Issues (P0301, Now P0301 & P0303)
Old May 7, 2025 | 07:54 PM
Yeehawsauce's Avatar
Yeehawsauce
Hey everyone, I’m looking for some help diagnosing a persistent misfire issue on my 2011 G37x Sedan with just over 108k miles.
It started two days ago when I noticed the car idling very roughly right after startup. I scanned it with an OBD2 reader and got a P0301 code—misfire on cylinder 1.
Naturally, I started with the basics:
  • Replaced all the spark plugs with new ones.
  • Swapped coil packs from bank to bank to see if the misfire would follow.
While doing that, I noticed a bit of oil in the cylinder 1 spark plug well, so I assumed it was the valve cover gasket. I replaced it the same day, used RTV where needed, and waited 24 hours before starting the car again.
Next day: still rough idle, and now I’m getting misfires on cylinders 1 and 3 (P0301 and P0303).
Did I mess something up? I checked again—no oil in the wells anymore, so the gasket job seems solid.
I then suspected bad fuel, since I had just filled up the night before the issue started. Maybe I accidentally put in something lower than 91 octane? I tried an octane booster, but it made no difference.
Next step: I swapped the fuel injectors between banks. Still no change—same misfire codes on cylinders 1 and 3.
Then I thought it could be the catalytic converters, since I’ve had a code for them in the past (I always assumed it was just a sensor). I removed the cats and inspected them—they looked fine.
Head gasket? Doesn’t seem likely:
  • No smoke from the exhaust.
  • Coolant looks clean.
Piston rings? Also unlikely, right? Wouldn’t that also cause smoke?
I even did a compression test on all cylinders, and the results were perfect.
At this point, the only thing I haven’t tried is replacing the MAF sensors. They seem fine, but just to be sure I’m going to AutoZone today to pick up new ones.
Honestly, I’m at a complete standstill. If the new MAF sensors don’t fix it, I’m probably going to have it towed to Nissan for diagnosis.
Any ideas or suggestions? I’d really appreciate the help.
Matta_Richard
Apr 9, 2026 04:58 AM
Mastodon
Dec 3, 2021 03:04 PM
Zachdeg
Jul 31, 2021 07:46 PM
DYLBER
Apr 7, 2021 09:16 PM
Kaotic Blue
Jan 26, 2016 09:14 AM
