Check engine light on > p010b > replaced MAF sensor -> car goes into limp mode
Old Feb 22, 2025 | 06:02 PM
liftacar's Avatar
liftacar
I have a 2009 G37x sedan. It’s been great but over the last 2 years it’s starting to give me some issues.
I’ve had it lock up on me while driving numerous times where the whole car goes in “limp mode”. It’s jerking forward and backward and I can’t accelerate beyond 20-25 mph. Usually if I turn the car off and let it sit then back on it’ll be fine for a little bit before happening again. The check engine light doesn’t always come on after this. But when it did it gave me the p010b mass air flow sensor code (this was about a year ago).
I reset the code and it drove perfectly without any issues for a few months. Then 2 days ago it locked on me again a few times. This time I figured it was time to finally take it in and get it replaced. Took it to a local mechanic who ran diagnostics and confirmed it was my MAF. They changed it (I made sure they ordered an OEM part and not an after market part) and it drove fine for about 1-2 hours. Then the same issue happened. Took it back and they reset it and said they had to change some settings for it to get used to the air throttle or something? Left the shop and drove a mile and happened again. Took it back and they kept it overnight. Said the hosing/connection had a crack in it and they ordered a new one to be installed.
Got a call this am and said it was good to go and that they even drove it on the highway (with my permission) and got it up to 60-70 which didn’t trigger anything. Went to pick it up and it happened again to me right around when I got to the same part every time before. Went back (now a 6th time). This time the mechanic wanted me to drive with him in the car. Drove around for 20 mins and drove super reckless (which I don’t normally) but I couldn’t trigger it to happen again. Afterwards he ran some diagnostics and nothing showed up. So I left. And of course it locked on me again around the same time as always.
Dropped it back off and they gave me a loaner car because they said they’ll have to call in someone else on Monday who handles any cars that they can’t seem to figure out.
I’m at a total loss right now as to what’s happening. He did take out both MAF and cleaned them real good (he said the other one was working perfectly and diags were spot on). He said it may be a piston issue?
Anyways, I just wanted to see if anyone here has any insight. This is all the info I have and I don’t want to take it to a Nissan/Infiniti dealership but I may have to. Also, I don’t know if this is my car telling me that it’s time to move on from it either…
Thanks in advance for reading and any advice
itengineer
Oct 2, 2024 07:09 PM
Helpmewithmycar
Jan 8, 2024 10:50 PM
Paul_G37
14
Apr 27, 2023 08:16 PM
PeTeToTe
Aug 29, 2011 11:45 PM
sobi6111
Oct 22, 2010 03:52 PM
