Car won’t start at times
Old Jan 21, 2024 | 01:27 PM
Shub's Avatar
Shub
Hi all,
I have a 2009 Infiniti G37x with 150k miles, it randomly doesn’t start at times. The car would crank and start but will shut down like it’s not getting enough power (kind of like a misfire). I have to press the gas pedal to make it start. Some days it starts normal without me having to do this. It would do this a lot of a cold day if I let it sit for like 12 hours but there has been times it did this on a hot day. There is no code, I’ve tried bringing it to the mechanic and dealer and they said since there isn’t a code, they can’t really help.I've also cleaned the MAF sensors but not the throttle body. Any suggestions on what this issue may be? Thanks!
Old Jan 21, 2024 | 02:30 PM
Krzysztof47's Avatar
Krzysztof47
Clean the throttle bodies, they are probably filthy and I remember reading people with your issue and dirty throttle bodies where the culprit.
Old Jan 31, 2024 | 12:34 AM
Martinez1041's Avatar
Martinez1041
As Krzysztof said,clean the throttle bodies. That’s one of the first things I did when I got my car. But I literally took the throttle bodies off and cleaned them. Just be careful with the screws on the throttle body. They are soft metal and it’s very easy to strip them. Also try to have a magnetic bit. I lost 2 nuts that are still down there somewhere. Probably fell on the crossmember or something. Definitely gone now
Shub
Aug 15, 2022 09:13 PM
Paul_G37
Nov 28, 2020 06:49 PM
MPdesign
General Tech Questions
Jul 3, 2012 09:34 AM
med8cal
32
Mar 22, 2008 10:53 AM
