G37S 6MT Standing Burnout
Old Oct 30, 2023 | 04:00 AM
AMP_01's Avatar
AMP_01
(REPOST because I never got an answer months ago)
Hello all, I finally got done with my yaw sensor switch (works like a charm!) I know to do a standing burnout at least in the autos you have to pull the brake light fuse or set up a switch for it, but I was curious if that was necessary for the manuals. Also, has anyone found a method to have the car think the fuse is out/switch is flipped, while keeping the brake lights operational?
Old Oct 30, 2023 | 09:56 AM
Huh? If I'm launching the car with TC off, I have to try hard just to avoid spin, wide summer-only tires notwithstanding. TC off, heavy throttle, pop the clutch, and your rear will spin place like butter.
Old Oct 30, 2023 | 10:07 AM
AMP_01's Avatar
AMP_01
I meant more just a constant standing "bye bye tires" burnout with the brake and the gas. I haven't tried it yet but just curious because with the 7AT the brake fuse needs to be pulled so the car doesn't cut power when gas and brake is applied at the same time. Was just curious if it had to be pulled for the 6MT.
Old Oct 30, 2023 | 11:46 AM
BULL's Avatar
BULL
Moderador
You can enable this with Uprev with ARC or Ecutek full without any physical change.
For DIY you'll need to locate pin 122 in the ecm and place a switch in between so it cuts the feed of brake input to the ECM and doesnt let it cut.
A switch will be needed or it will throw a CEL. It will still throw the CEL however a re-start with the sw enabled and your lights will be off.
Old Nov 1, 2023 | 10:09 AM
beefychicken's Avatar
beefychicken
Try this thread, post #69 has a really cool diagram.
https://www.myg37.com/forums/showthr...errerid=369648
Old Nov 1, 2023 | 11:19 AM
AMP_01's Avatar
AMP_01
Is needing to cut the brake fuse required to do it in a manual transmission or only the autos?
Old Nov 1, 2023 | 11:20 AM
AMP_01's Avatar
AMP_01
Thank you for linking that it hadn't shown up on my search surprisingly!! Is needing to cut the brake fuse required to do it on the 6mts or just the autos?
Old Nov 1, 2023 | 04:45 PM
beefychicken
Not sure if you need this mod or not on the 6MT.
But taking advice from @Rochester find a track or other approved burnout location and see what happens. if you dont get the response you need, then try installing the mod and see if that gets you where you want to be.
Once you figure all of this out, update this thread with your reuslts for the next person down the road who may have the same concern.
Old Nov 1, 2023 | 05:03 PM
Well, any place can be an approved burnout location if you're willing to man up when you get in trouble.
It's a crazy thing to see an entire neighborhood get filled with white smoke. Can't say as I recommend it, but it's a sight to see nonetheless. Kind of like burning off Seafoam.
Old Nov 3, 2023 | 09:51 AM
BULL's Avatar
BULL
Moderador
It depends on what is it you're trying to achieve. Sometimes during a Burnout you release the brake and re-apply. Sometimes to shift to 2nd gear, sometimes to do a rolling burnout.
The car might allow a standing burnout however as soon as it reads front wheel speed it will kill the accelerator.
tokyojoe240
Drivetrain
Jul 8, 2023 07:46 PM
AMP_01
May 4, 2023 10:44 AM
Devil_g37
Feb 6, 2022 10:44 PM
Louiegee97
May 29, 2016 05:28 AM
