Vibrations possibly suspension related
I have a 2010 g37x sedan a short while after buying it started having vibrations over 30 mph when moving the wheel left. either lane changing or left turns it vibrates you can feel it in the steering wheel but only very slightly it’s more of a noise you can just hear. i’ve replaced the front left wheel bearing, both tie rod ends being that they were worn, pads and rotors, and both sway bar end links. i’ve still been hearing this noise after all of this. i’ve inspected the cv axles and they’re still in good condition boots as well. however I noticed the motor mount is looking worn on the front driver side and plan to get solid mounts from z1 I don’t know if this will fix this problem anyone experience this as well?
James Osumah
Sep 27, 2019 01:44 AM
Steveo47
Jan 8, 2011 12:21 PM
