Big Brake Upgrade Help
Old May 30, 2023 | 12:32 PM
Samrat101's Avatar
Samrat101
Hey guys,
I was looking through the threads but couldn't find any information on the mounting bolts I'll need for the big brakes. Can I use the bolts from the non-sport caliper? If not, does anyone have sizes or part numbers for the bolts?
Thanks in advance!
Old May 30, 2023 | 05:12 PM
Martinez1041's Avatar
Martinez1041
If you’re just using the akebonos then they bolt up. You have to either trim or remove the dust shield as the bigger rotors won’t clear the oem shield. You need shorter banjo bolts. The non sport ones that come on non sports are too long
Old May 30, 2023 | 09:35 PM
Krzysztof47's Avatar
Krzysztof47
Originally Posted by Samrat101
Hey guys,
Thanks in advance!
The front calipers use a special blue bolt: 41005-1MD0A (You will need 4X for the front). You can reuse the original, but it will take a different torque spec. Blue bolt: 91 ft/lbs, original bolt and washer: 98 ft/lbs.
For the rear I reused my original floating caliper bolts as it uses the same: 08044-2351A (bolt), 01311-01251 (washer). Rear bolt torque spec: 62 ft/lbs.
Old May 31, 2023 | 12:14 AM
Martinez1041
I didn’t know that about the blue bolt. Funny thing is,it’s actually a blue bolt. I find that hilarious
Old Jun 7, 2023 | 09:25 PM
Samrat101's Avatar
Samrat101
Thank you for your help! @Martinez1041 @Krzysztof47
Old Jun 7, 2023 | 09:29 PM
Krzysztof47
No problem, hopefully the upgrade went well!
AdamBritt
Apr 6, 2024 09:36 PM
swaybar
Jun 10, 2021 08:12 PM
shakysco
Mar 23, 2018 10:01 AM
KungFooFireman
May 6, 2017 04:01 PM
nycty
Sep 27, 2013 09:25 AM
