Bcm getting wet
Old Jan 10, 2023 | 12:21 PM
capon30's Avatar
capon30
Bcm getting wet
My bcm is getting wet . Found where the leak is however , my windows dont work interior lights dont work . Car doesnt lock with the key or inside . Only opens with the key. Now my windows is stuck down ….. im clueless on what to do
Old Jan 10, 2023 | 12:32 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Disconnect battery.
Disconnect and remove BCM.
Take BCM inside and make sure it is completely dry.
Make sure all of the connectors are clean and dry. A can of compressed air shot into each terminal will help.
When everything is clean and dry, plug everything back up, reconnect battery, and cross your fingers.
If you're lucky the BCM will return to normal. If not, it will have to be replaced.
Old Jan 10, 2023 | 12:35 PM
capon30's Avatar
capon30
Okayy will try that thank you
Old Feb 4, 2023 | 10:46 AM
ILM-NC G37S
First, the number you provided is NOT the part number (p/n). The p/n should read 284B1-xxxxx (the last 5-digits will be specific to your car). If you are getting a used BCM (from eBay, ie) then the DONOR car must match your car (sedan, Coupe, or 'Vert). It is NOT suggested you "mix-and-match" them.
Any replacement BCM will require reprogramming. That said, any qualified, reputable locksmith should be able to sync your keys to the "new" BCM. I would call around and see who provides the best service.
It goes without saying, repair the source of the leak prior to commencing repair on the BCM else the issue can/ will present itself again.
Old Jul 25, 2024 | 04:39 AM
Jacob1917's Avatar
Jacob1917
I'm having the same issue. My BCM is 284B1-1EJ5D, I bought a BCM that is 284B1-1EJ4C buts still from the same car. Would the dealer be able to program it?
JBeezy313
Aug 6, 2022 01:55 PM
ug2215
General Tech Questions
Jan 1, 2019 12:00 PM
Ibanez540r
Jan 15, 2012 02:50 PM
g37brad
Apr 21, 2010 04:09 PM
cullan
Oct 20, 2008 05:55 PM
