Rough idle and acceleration but no check engine light
Old Sep 27, 2022 | 05:01 PM
Camgarcia19's Avatar
Camgarcia19
Rough idle, please help. Im not a big gear head so I hope someone can help me out. I was driving home the other night and at a stop light my engine gave a couple stutters. As I accelerated I could feel it running rough ( shaky and such). The check engine light blinked for like 5 seconds then turned off. There is no standing check engine light on or anything, so I can't read any codes with an obd reader or anything. Maybe someone has had a similar issue in the past and has a solution. Thanks for any and all assistance.
Old Sep 27, 2022 | 08:15 PM
G37sPhoton's Avatar
G37sPhoton
That sounds very similar to my situation... no engine code for a few days actually and then eventually at idle, rough and jist sounding horrible, it came on and went off and on and off etc... but was enough to give me P0304 (cylinder misfire#4) . Most articles said start with coil pack... thats where i am now... switched it to 2 and the code followed to P0302 ... so bought a $30 one from amazon but code remains... bought new boots and switched them out with the original and still showing code... but if you saw engine light blink, some code will be stored ...
Old Sep 29, 2022 | 06:37 PM
blck-magic's Avatar
blck-magic
What kind of intake do you have and was it raining? Honestly sounds like a bad or dirty mass airflow sensor. That will definitely throw off the idle
Old Oct 5, 2022 | 08:10 PM
G37sPhoton's Avatar
G37sPhoton
Any luck? I changed coils from #4 to #2 and code went to p0302, so was figuring the coil pack... bought an off brand from amazon and code remained, however it did run normal for a few days until i drove a little further on a hot day and it all csme back. So bought oem coil pack and still same code. Got new denso plug and replaced and still same code... i cleaned MAFs , throttle bodies and PCV valves and still same code... so finally switched back 2 to 4 and same code... hope yours is easier to fix and if you did please share...
soldier9599
Jun 16, 2020 02:04 PM
chenz19
Nov 2, 2019 06:54 AM
davelim
Jan 16, 2012 06:55 PM
who?
Feb 26, 2011 11:21 AM
G37SUM!
Apr 2, 2008 03:33 PM
