automatic transmission oil tempratures with torque app
Old Mar 11, 2022 | 04:47 PM
nr1asaf's Avatar
nr1asaf
Question automatic transmission oil tempratures with torque app
Hello,
I am having trouble reading my automatic transmission oil tempratures with torque pro. It shows the value -56°C for both input and output (most of the other important PIDs seems to work fine).
When I go to the PID editor and try to test the PID it shows me a toast that says:
“OBD Header incorrect(‘Auto’ or hex(eg: ‘7E0’,’6A6C1F’) or ‘TCM’,’ABS’,’INS’,’PAM’)”
the current header is “7E1” for both the input and the output.
I am using PIDs that are imported from an excel file. (Attached the file here)
the friend who sent me the files connected his Bluetooth OBD and his phone to my car, and the PIDs worked fine for him.
The car is G37 sedan 2012.
I am using “ELM327 USB OBDII” (colored orange and blue).
Thank you
File Type: csv
Old Mar 11, 2022 | 10:27 PM
beefychicken's Avatar
beefychicken
Looks like the excel sheet may have been corrupted or formatted incorrectly.
Old Mar 12, 2022 | 02:29 PM
beefychicken
Downloaded again and ran it, it loaded fine this time. Haven't checked it on the car yet.
Old Apr 1, 2022 | 11:17 AM
beefychicken
Originally Posted by nr1asaf
Hello,
Thank you
It works with my setup. Only thing is when i use the PIDs from the attached sheet, Torque stops updating all of the other sensors, so the only things that update are the trans temps.
Old Apr 1, 2022 | 11:32 AM
nr1asaf's Avatar
nr1asaf
thank you.
I just bought another OBD adapter (more expensive one), and it works as I wanted it to.
Old Apr 1, 2022 | 12:19 PM
BULL's Avatar
BULL
Moderador
I gave up on it and used OBD fusion to get those temps.
Old Apr 1, 2022 | 12:58 PM
beefychicken
thank you.
Which adapter did you purchase?
Old Apr 1, 2022 | 12:59 PM
beefychicken
I used OBD Fusion, Trans temp worked great but had trouble getting the Oil Temp to work. Are you able to get oil temps?
Old Apr 1, 2022 | 04:35 PM
nr1asaf's Avatar
nr1asaf
Amazon Amazon
NewEnglandG
General Tech Questions
Dec 12, 2017 05:11 PM
xnick101
Apr 8, 2016 11:03 AM
bythabay
12
Dec 16, 2010 02:44 PM
JfromTheBay
12
Sep 8, 2010 11:20 PM
G hits the spot
12
Jul 20, 2010 12:31 PM
