Leaking gasoline
Old Sep 20, 2021 | 08:57 PM
carlos27's Avatar
carlos27
Leaking gasoline
Yesterday I noticed that this **** was leaking gas anyone have the same issue !?
Old Sep 20, 2021 | 09:13 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Fuel damper. It is rare for those to fail/ leak, but anything is possible. Where is the gasoline leaking from - the rubber hose or the metal housing itself? Either way the whole unit gets replaced. Here is a link to replacing the damper.
If you are not comfortable/ skilled in doing these type of repairs, I would strongly suggest you find a qualified, trusted mechanic to do the job. It should not take more than a hour, 2 at most.
Old Sep 20, 2021 | 09:29 PM
Dzionassi's Avatar
Dzionassi
There is an rubber o ring. Probably it is damaged. If this is your problem its like 2 min job...
Old Sep 20, 2021 | 10:28 PM
ILM-NC G37S
Good catch. That all depends on where the gasoline is leaking from. If gas is leaking from between the two flanges, then replacing the o-ring will likely solve the problem. If the leak is from the rubber hose or from the metal damper housing itself, that will require replacement. This diagram may help:
Again, OP, where is the gas leaking from exactly?
Old Sep 21, 2021 | 06:22 PM
carlos27's Avatar
carlos27
I noticed it’s leaking from the metal housing but I’ll make sure to check the hose as well thanks you guys are awesome !!
hbaz
General Tech Questions
37
Oct 22, 2008 12:36 AM
