2013 G37 Valve Body Swap
Old Sep 13, 2021 | 10:32 AM
bmeutzner's Avatar
bmeutzner
Recently went into limp mode and pulled error code P0725. Ordered a new output speed sensor and "remanufactured" valve body just to be sure.
After replacing both and re-filling 9.2 qts of fluid my car won't start... receiving U0101 now "can't communicate with TCM".
As far as I can tell the replacement valve body and TCM is identical to what was in the car to begin with... confident that wiring harness to TCM is hooked up cleanly and no pinched/broken wires.
So am I missing something or did the valve body unit I ordered have a faulty TCM? I've checked A/T fuses, reset ECM, shifted through P-R-N-D a few times to ensure shift position is correct (which doesn't show on the dash display by the way), charged up the battery just in case.
Does the "new" valve body need to be programmed? (they're supposed to be plug & play as per seller description.
Looking for some ideas/help... thanks in advance.
Old Sep 13, 2021 | 05:05 PM
bmeutzner's Avatar
bmeutzner
**SOLVED**
Apparently I did not check "all" the fuses. The large fusebox to the side of the battery was missed :-(. Sure enough, fuse blow, fuse replaced, and no more error codes!
Old Oct 14, 2022 | 10:01 PM
g37dom's Avatar
g37dom
Originally Posted by bmeutzner
**SOLVED**
bro pleaseeeee tell me you get the email that i replied to this and tell me what fuse it is lmao literally in the same position. no idea what fuse it is, im gonna check them all tmr but if u could tell me thatd be great.
Old Dec 25, 2022 | 01:30 PM
12JourneyCpe's Avatar
12JourneyCpe
Same exact issue please let me know which fuse to replace
**SOLVED**
Same issue with my g please help with which fuse to replace
Old Dec 25, 2022 | 01:31 PM
12JourneyCpe
same here bro did you find out which fuse to replace?
Old Sep 7, 2023 | 11:14 AM
idyllic420's Avatar
idyllic420
were you able to figure it out ?
Old Sep 7, 2023 | 11:36 AM
BULL's Avatar
BULL
Moderador
Old Sep 7, 2023 | 02:42 PM
idyllic420's Avatar
idyllic420
Originally Posted by BULL
thank you. Is this in the fuse box near the parking break ?
is this the fuse box that is near the parking brake ?
Old Sep 9, 2023 | 10:24 AM
13_SkylineSedan's Avatar
13_SkylineSedan
No, it's in the IPDM in the engine compartment behind the battery. Here's a picture of fuse 43 (from a 2013 G):
Old Jan 15, 2024 | 04:11 PM
highbrowed's Avatar
highbrowed
Hi I am having this same issue with my 2012 G37x coupe. Won't shift past 3rd and getting a P0720. Where did you purchase your remanufactured valve body from?
Old Jan 15, 2024 | 06:58 PM
Krzysztof47's Avatar
Krzysztof47
I had that issue when my TCM went bad, new OEM one was put in and had to be programmed.
Old Feb 27, 2024 | 11:36 PM
mingjai89's Avatar
mingjai89
How much did you pay for a new TCM?
Old Feb 28, 2024 | 01:07 PM
Krzysztof47
I believe it was around $2400 for everything.
jmitch421
27
Mar 11, 2024 10:07 AM
Tecno
General Tech Questions
Nov 7, 2020 07:54 PM
venmichaels
12
Nov 27, 2017 04:40 PM
Raiko
Aug 1, 2015 05:01 PM
fkat
Jan 2, 2011 01:21 PM
