Left Rare Wheel alignment issue
Old Jun 1, 2021 | 12:48 PM
pkolla's Avatar
pkolla
Hi
I went to firestone to get my wheels aligned and he mentioned that the left rare toe can't be aligned and that is the best your car allows it for. Below is the pic of wheel alignment.
does this screw up thread on left rare tire.
Do we have an alternative to fix it? And this car never had an accident, the mechanic mentions there could be an accident or something which pushed something to missallign ..
Any suggestions?​​​​​​​
Old Jun 1, 2021 | 07:04 PM
spoolin03's Avatar
spoolin03
That rare toe
Old Jun 1, 2021 | 09:44 PM
Said Amir's Avatar
Said Amir
https://www.splparts.com/products/37...toe-bolts.html
You can install these, and there is bunch of videos and information in the forum on installing it. On the subframe you will need to enlarge the hole and it comes with a templet to mock it up. However I am not 100% sure if it will fit the oem control arm, or if you will need to upgrade the rear control arm also to make it work. Hopefully someone can chime in.
Old Jun 2, 2021 | 09:25 AM
pkolla's Avatar
pkolla
yes, I saw some videos about that. But curious why the OEM parts doesn't fit Infiniti own recommended numbers.
Also is the left rare Toe numbers way too much off? Sorry I am not sure how to understand these numbers. Does this cause too much wear on the left rare time? or Is that variance too little to cause the issue?
Old Jun 2, 2021 | 10:43 AM
Said Amir's Avatar
Said Amir
Yes that is a lot of toe angle and it will cause your tires to wear out a lot faster. You usually want to stay around 0° or a little higher specially on a daily driver.
doctorg37xs
Jan 17, 2019 07:45 AM
Tomer
Jan 11, 2019 03:50 PM
drizzy315
Sep 22, 2018 01:23 PM
Varjo
Jan 31, 2013 11:31 PM
911turbo
Feb 24, 2011 10:46 PM
