VR30 trans swap 2013 Sedan
With VQ 7-speed
With VR 7-speed (Don't mind the fluid, I had just popped it out and back in so it dribbled a little). Note the cutout to the transmission mounting brace to accommodate the new transmission. The cutout does not seem to affect the sturdiness of the mount. I also had to cut/shorten the shifter linkage as you can see from the photo where I cut and put a blob of weld (a ****ty one) on the linkage.
With VQ 7-speed
yea, this is mine
How do you like the CF driveshaft? Do you notice quicker revving?
I see some space there, if that measures half an inch then it *might* work or might not. Maybe take it to a driveline shop to shorten it for you, might be cheaper than getting a new one.
slotterjordan
12
Jul 7, 2016 12:37 PM
Ali6767
Jun 30, 2015 05:18 PM
