Front Emblem Alternative Method for Removal
Old May 21, 2021 | 08:48 PM
Krzysztof47's Avatar
Krzysztof47
I saw people take the radiator shroud off to get to the clips to remove the front emblem, or they use their middle fingers to snake around and pry the clips apart. I found a simple way to do it with a small hook tool if you can't reach with your fingers and don't want to take the radiator shroud off. Takes only a couple minutes.
Tool I used is a simple "hook pick hose removal tool". Just place it where you would use your finger to get at the clips. Does not take a lot of force to release the clips, once you get one side done, do the same for the other and the emblem will pop out.
Tool:
Amazon Amazon
Old May 24, 2021 | 01:47 PM
G37sPhoton's Avatar
G37sPhoton
Also, if you got any of the paint can lid openers lying around...they work too, but otherwise, good idea, as i tried and fingers died that day lol
Old May 25, 2021 | 07:08 PM
Krzysztof47
Thanks! I tried and could not get around to the clips with my fingers.
jking
May 11, 2012 02:34 PM
BuzzLY37
Jan 23, 2011 07:49 PM
NiTeHawKPwNeD
Mar 25, 2010 07:15 PM
gtracing
Feb 17, 2010 03:37 PM
Skyline-LEXY
General Tech Questions
Jul 11, 2008 04:46 PM
