G37 ac issue
Old May 1, 2021 | 05:21 PM
Bryce McCaskill's Avatar
Bryce McCaskill
G37 ac issue
What’s up guys Im having a bit of an issue. I had to replace my expansion valve not long ago and after installed everything back the blend door motor would not work. I’ve called three different auto parts stores and for some reason they don’t have anything. Even tried looking as a Nissan but no luck.. where can I get another?
Old May 1, 2021 | 07:53 PM
ILM-NC G37S's Avatar
ILM-NC G37S
I think eBay will be your beat bet on sourcing those motors. I did a quick check using "G37 Blend Door" and there are a few different listings.
Did you run the self-diagnostic function to determine if it was the blend motor or maybe something else? There is quite a extensive diagnostic function that is detailed in the HAC section of the Factory Service Manual .
Old May 1, 2021 | 08:57 PM
Bryce McCaskill
If you’re talking about the fuse test that checks lights wipers compressor/clutch and fans then yes.
Old May 1, 2021 | 09:36 PM
ILM-NC G37S
No, that is the IPDM/er self-test.
There is a entirely separate diagnostic function built into the HVAC system: it tests the AC Amp., switches, sensors, actuators, blend motors, potentiometers, etc.
Old May 2, 2021 | 08:59 AM
Bryce McCaskill
Im going to check that now, thanks.
Cordovarandy
Apr 2, 2021 10:14 AM
Tee Pizzle
Jul 16, 2020 11:01 AM
Snaoum
Jun 28, 2019 03:14 PM
jbusbygbtc
South
Jul 31, 2013 10:35 PM
Wicked_limitz
May 6, 2009 04:26 AM
