Passenger seat wont move forward (sometimes)
Old Feb 9, 2021 | 04:48 PM
Mojo_Dp's Avatar
Mojo_Dp
I have just noticed when I tried to move my passenger seat up it won't move, other times it works just fine. I have to fiddle with it back forth a few times and it'll move. Everything else works, tilt back and front, height, and moving back. Is the whole switch going bad or could it be something else?
Old Feb 10, 2021 | 09:54 AM
BoomerSpeed01's Avatar
BoomerSpeed01
If you don't hear any grinding or motor whine when it doesn't move for you, then it is probably that direction of the switch going bad. Should be able to find a new switch relatively easily.
If you're willing to remove it yourself you could also just see if there's some sort of debris blocking the contacts inside the switch.
Maybe just get one of those cans of pressurized air and see if blowing out the switch does anything first.
dholifield
G37 Convertible
Aug 14, 2018 09:09 PM
twerk
Aug 5, 2011 10:11 AM
agentzero
Feb 16, 2010 05:55 PM
Weiboy718
Jan 4, 2008 01:20 AM
