Throttle body swap Question
Old Feb 5, 2021 | 03:29 AM
JME377's Avatar
JME377
Will Maxima larger 70mm throttle bodies fit on VQ intakes from a G37 without any modifications? I saw that swap on a 370Z and was wondering will it work for my G37
Old Feb 5, 2021 | 01:51 PM
projectpanda13's Avatar
projectpanda13
to make it work, you need a transition plate/adapter. EPS sells a kit, throttle bodies, wire harness (just 1 for the passenger side, not needed for the driver side), and the adapter plate.
Simplistic Garage sells a kit for 75mm throttle bodies.
Old Feb 5, 2021 | 05:15 PM
JME377's Avatar
JME377
Is that transition plate to make up for the size difference? And is that spacer really needed?
Old Feb 5, 2021 | 06:52 PM
projectpanda13
i forgot how the mounting location of the TB relative to the manifold opening is, but here is a picture to show the difference in diameter.
without the transition adapter, it’s a big drop off and will disrupt the air flow.
TakmaN
Oct 16, 2018 08:31 AM
JakeG37
Apr 20, 2018 12:05 PM
kdawg8526
Intake and Exhaust
Apr 15, 2013 04:21 PM
