Which test pipes?
Which test pipes?
I have a Motordyne E370 Shockwave on my G and I currently have stock cats. I wanna move towards test pipes but I don’t know where to go. I don’t wanna spend a crazy amount of money (I already did on the exhaust). What sounds best HFC, resonated, or unresonated?
Already haveing a shockwave exhaust, if you do any option that's catless you're going to be significantly louder, and there will be a big differenct that you'll definitely notice.
If you just want it to get a little louder and gain a little HP, do HFC.
If you want all the power and ALL the sound do just straight test pipes. If you do resonated test pipes, make sure the packing material is the steel wool style and not fiberglass. As hot as it's gonna get, fiberglass will burn out very quickly and you'll end up with a non-res test pipe anyway.
Art pipes as mentioned will get you all the gains with also very very good sound. They don't take anything away from the volume of the exhaust. It just takes out the resonance that just comes out as "noise" otherwise. If you listen to G's with the shockwave that have art pipes and ones that have normal test pipes, you should be able to hear the difference.
Basically it depends on what you want to get out of the exhaust. There's no right or wrong, other than the one wrong would be getting the fiberglass resonated test pipes.
Not sure if this is your cup of tea but ART pipes CAN be an option if you want them bad enough :
https://www.google.com/amp/s/amp.red..._a_g37x_coupe/
ave233
Jul 29, 2014 09:56 PM
SOLISIMO
24
Feb 4, 2009 08:00 AM
LAZY TURBO
Intake and Exhaust
65
Apr 20, 2008 08:11 PM
