Spare removal results in low rigidity of trunk liner
Old Dec 3, 2020 | 02:02 AM
AnotherVQ's Avatar
AnotherVQ
Going to remove it eventually anyway when I install airbags.
I won't be paying for a tow. Read the thread. Also, read the thread to answer other question.
Also question was about providing stability, not asking if people think it's a good idea to do it.
Old Dec 3, 2020 | 03:16 AM
Joyryde's Avatar
Joyryde
No offense, for me personally having a dude come over and change my tire for me is one of the most emasculating things I can imagine. If you’re not on bags yet, also a bad decision from my experience, why did you remove the tire? Why not make some foam stilts for the spare area?
Old Dec 3, 2020 | 03:17 AM
AnotherVQ's Avatar
AnotherVQ
I think something like that will be happening. Maybe hold off for now on removal and wait for the air setup.
Old Dec 3, 2020 | 03:55 PM
sobeIPL's Avatar
sobeIPL
Buy a couple yoga blocks on Amazon. They are like $5 each. Virtually weightless, will provide shrunk floor stability and should be pretty spot on to the size needed to fill spare tire gap.
Old Dec 5, 2020 | 04:41 AM
KEVON1's Avatar
KEVON1
You do you....A buddy of mine asked me the same question in my driveway ....
I went into my garage a pulled out a large heavy duty trash compactor type garbage bag .
I sprayed a light coating of 3m adhesive inside the bag and poured in packing peanuts about quarter of the way , put the bag in his spare tire area and shaped it from the outside of the bag to the exact shape of his spare area , opened the bag and poured in more peanuts & sprayed more adhesive and repeated until flush and level with the surrounding trunk area then went at it with more than enough adhesive and sealed the bag with a zip tie .......Within minutes it was hard as a rock and a perfect fit that weighed next to nothing . Pull the carpet back and done ......it is extremely supportive as well and removable as it turns into a solid block
munzer
Nov 19, 2020 11:19 AM
G37xS-Life
Aug 8, 2016 03:34 PM
strictlys
Nov 9, 2013 12:12 PM
Serbiasrt8
Jan 19, 2009 12:01 PM
Yimbie
Jun 26, 2007 10:23 AM
