Finally drove the 6mt sedan!
Old Mar 3, 2020 | 09:55 AM
bellv83's Avatar
bellv83
Well after 6 weeks of owning it and only driving it 1 mile or so to the store 1 time, the Airlift is off, stock shocks with Swifts, Eibach bars, powder coated wheels with 15mm spacers and some new tires. A ton of general maintenance✔️. First real drive this morning and I dig it!. 2012 6mt 54k. Off to alignment in a few days and baby seat for my homie going in. Time to enjoy it
Old Mar 3, 2020 | 10:03 AM
Front chin, rear spoiler, OEM flaps, full tint, lowered and spaced and duckfeet in gunmetal... very nice.
Old Mar 3, 2020 | 10:06 AM
bellv83's Avatar
bellv83
@Rochester thanks for the suggestions in getting it going
Old Mar 3, 2020 | 12:56 PM
bellv83's Avatar
bellv83
Can anyone chime in on sway bar setting. I have them set on the middle hole in the rear and the outer or soft in the front. My rear is snapping too easily, what can I do to plant the rear more. Stiffen the front, soften the rear, both?
Thanks
Old Mar 3, 2020 | 01:06 PM
Snapping? Do you mean you're losing grip in the rear before the front? IDK, I'd rather play into over-steer and correct it than have to fight against under-steer..
Someone is going to give you good advice about which connection points to use on your swaybars. And I suppose one potential solution to what you're describing isn't necessarily something you're going to do anytime soon, which is a wider rear wheel & tire setup.
Old Mar 3, 2020 | 01:16 PM
bellv83's Avatar
bellv83
Good question, felt the the traction was stopping the rear to me but I will turn traction off and see what the car tells me on the way home. With optimal bar setting to balance the car I would be fine with it, not going to change the wheels. The front is already soft, this is soft correct? So the front should not be pushing. I guess that would leave the idea of the rear is letting go and make adjustments targeting more rear grip
Old Mar 3, 2020 | 04:13 PM
slartibartfast's Avatar
slartibartfast
Stiffer front = understeer.
Stiffer rear = oversteer.
Stock suspension and tires with nanny off can easily snap oversteer with injudicious use of the throttle. Be careful out there.
Old Mar 3, 2020 | 04:21 PM
bellv83's Avatar
bellv83
yea thanks. Thinking of softening the rear and see how they goes. If more is needed Ill stiffen the front but like i said it was on Airlift so the alignment may just be so far out so I'll wait till thats done.
Old Mar 3, 2020 | 09:47 PM
RobC7's Avatar
RobC7
Is the spoiler painted in black? If so I recommend painting the mirrors and blacking out the window moldings, I think it will bring it all together.
What % is your tint?
Old Mar 4, 2020 | 06:56 AM
bellv83's Avatar
bellv83
Not black
Looks like 20%
ZahyMatar
Mar 26, 2017 04:53 AM
rpm&my_G35
Canada
Nov 7, 2015 05:49 PM
Daddy Fat Sacs
Jun 9, 2014 01:50 PM
Roca
Jul 5, 2012 07:22 AM
bobbybouchet
Jul 16, 2009 11:39 AM
