G37S sedan / winter driving - hills
Hello guys,
Haven't been on here for a while, nice to see people are still active.
During my "hiatus", we ended up moving from Houston to Jersey and now that we are here, I'm a little bit worried about the G and winter driving.
I know I've seen several threads on this matter and from reading on those, I should be ok as long as I get proper winter tires for the ride. Thing is, it's very hilly around where we are at and I'm worried about sliding somewhere when that snow starts to hit out here.
You guys think I should worry at all or should I blow the trigger on trading her in for something AWD? (don't really want FWD)
it's a '13 G37S sedan, Auto 7sp with 63k (love the thing)
thanks!
thanks!
Dont trade your G, especially if you love it! Jersey isn't too bad for snow. The dangers of icy hills are stopping distance and corner grip. Both are primarily dependent on tire compund AND driving style. Give yourself double the room for stopping. Even with good tires!
If you've never lived in blizzard country, get a good set and practice in an empty lot on the first snow. You do have to be diligent about controlling that lead foot, but a RWD with proper throttle control and a good winter shoe will outdrive an AWD CUV on all-seasons every single day. As a teen, I learned to drive in winters with a 2001 335ic BMW. It would have been a proper weapon if I didn't have snow tires and plenty of parking lot snowcrosses with my dad.
TLDR; Get cheap OEM rims (there may be a $77 rims link on this site still), and the best winter rubber you can get. AND give yourself double the stopping distance.
I find driving with winter tires on a S sedan to be acceptable. Stopping has not been an issue (chicago is relatively flat after all). Where I do find issue is turns. The tires I use (michelin xice 2) just don't grip well when making turns in snow/slush. The car understeers severely. Also, while possible to take off without wheel spin, too much throttle results in wheel spin. Too much doesn't even mean a lot, just enough to exceed available traction.
Both of these issues are mitigated by maintaining safe speed, keeping good following distance and exercising common sense
Yes I do, pain in the neck finding other 18's to fit. Thinking about using stock Enkie wheels it has with winter tires and then getting another nice set for summer.
Here's a tip: avoid High Performance snow tires, and get studless Ice & Snow tires, like Micheline X-Ice. Any snow tire marketed as "high performance" will be lacking in dry/wet pavement performance, and lacking in ice & snow situations. It's not the best of both worlds.
Personally, I think NJ winters are relatively warm, and less challenging than just a few hundred miles north.
That's always been my MO. Summer wheels and high-performance, summer-only tires, winter wheels and snow tires. If you add up $100+ tire swaps twice a year, after 5 years you blew a grand on tire swaps. If you ever think you might like a nice set of aftermarket wheels, your summer vs. winter needs helps make that decision.
For a number of years I was using Bridgestone Blizzak LM-60, and they sucked. Two years ago I replaced the rears with Michelin X-Ice, and ran both together. Much better forward traction. This winter, I'll be ditching the Blizzaks in the front and replacing them with X-Ice.
Maybe I just have higher expectation of winter tires. I don't remember having such issues when I had blizzaks (ws15? or 40... This is around 2001) on the camaro. They bit much better into snow.
Next time around will probably go with general winter tire of some sort. Problem is I drive the car so little and even less in the winter. Current tires have less than 4K miles on them over 7 winters. At this point age might be contributing to diminished performance too. Will probably go another 3 winters then replace them.
I have a 2011 S and the original equipment UHP summer Bridgestones were garbage if you even said the word snow. I replaced them UHP all seasons, first Hankooks and now Yokohamas, and they were fine for use here in the Baltimore/Washington area.
