Rear subframe bushing
I got my oil changed today at an Infiniti dealership today. After the service was done they gave me my report of the free inspection and this is what I got back.
Transmission mount is collapsing, has excessive movement - $459+tax
Upper radiator hose seeping - $219+tax
Rear subframe bushing torn at bottom. Dampening fluid leaked out bushing comes assembled into subframe - $2680+tax
Anyone else have these issues? Radiator hose is a simple fix, but the other two sounds kinda complicated. Thanks for any input.
My car is a 2013 G37S 6MT with 50152 miles on it. I have KW V3 coilovers along with Hotchiks sway bars with SPL front and rear endlinks.
Oakenfire (05-11-2020)
wowwed (09-18-2017)
The transmission mount is a 1/2 hour install for a mechanic, and that includes lift time. At worst, you'll get a minimum one hour charge. So buy the part yourself and have a local shop do the work. An aftermarket transmission mount (like Z1 Motorsports) runs $200, however it's not for everyone. Lots of NVH.
The upper radiator hose can't be more than $25, and is completely accessible as a DIY project for anyone. That price they quoted you was probably inclusive of a coolant flush.
The main rear bushing is a known point of failure. Unfortunately, Nissan only sells this as an installed component to the entire subframe, hence the many thousands of dollars. Still... that's nuts. An aftermarket kit (like Whiteline) will cost you $100, and expect another 4 hours labor at a good shop. Even if they charge you an entire day for the job, it's still a massive savings over the quote you got.
wowwed (09-18-2017)
rear bushing
Is this the part you're talking about Rochester? Which kind coolant would you recommend I put in after I change out the hoses? I'm planning to just do a coolant flush since I'm replacing the hoses. I'm replacing the hoses with the Z1 silicone as the OEM go bad. There seems to be a lot different ones and certain color matters.
wat happens if a person doesnt do the sub frame bushing replacement? i believe mine popped a while a go before i bought the car. there is no noise from movement or anything. for me ima just leave it doesnt seem to have any neg effect. id recommend same for op unless theres something going on back there
wowwed (09-18-2017)
wowwed (09-18-2017)
I hope nothing bad will happen if I don't replace it. I plan on keeping this car until it completely dies. I ideally would like to keep it running as good as possible. I'm still trying to figure which part that actually needs to be replaced. I'll probably jack up my car next week and take a peek around to look for it.
rear bushing
wowwed (09-18-2017)
wowwed (09-21-2017)
