Some advice & help please
Old May 10, 2017 | 03:05 AM
Kpmikey808's Avatar
Kpmikey808
Thank u for ur help
They will fit nice & flush, but I'd only go with them if you're lowered or plan on lowering. 20s exaggerate the already large fender gap at stock height. FWIW Natalie used to have one sweet black G sedan decked out in super flush Vossens, so she knows her stuff. And they are the lighter & stronger version of the Vossen line so an even better deal.
[img]webkit-fake-url://a8c5c48a-9b1f-4e8d-bb75-875b613d2c2f/imagepng[/img]
I ended up getting this
20x8.5 offset 35 245/35/20
20x10 offset 45 275/30/20
i wanted to say thank you for the advice & help with the rims- this was owners old car- ordered hub centric rings & tapered lug nuts like u told me - thx for info
Old May 10, 2017 | 08:28 AM
Glad it worked out! That will be a good fit w/ those specs. Now you'll want to lower your G
Old May 15, 2017 | 09:10 AM
Kpmikey808's Avatar
Kpmikey808
With these rims ☝️decided to go tein s spring
1.9 front
1.8 rear
With that drop I'll order spc control arm & toe bolt camber front & rear
Could u assist me where to buy - I've heard of those company's giving u bogus/fake parts
I looked at vendor onsite- how's the easiest & cheapest way of ordering all that
Old May 15, 2017 | 09:12 AM
Kpmikey808's Avatar
Kpmikey808
Woops was getting this info to u
Could u help me with this please thx
& is there anything else I need to buy to make ride smoother too
Old May 15, 2017 | 02:40 PM
I'd buy the Tein Basis Z coilovers, only cost a couple hundred more than the springs and will be a better overall setup and you can get the EXACT height you want.
Check JM autosports, should get you a good deal.
Old May 17, 2017 | 08:43 PM
Kpmikey808's Avatar
Kpmikey808
Tein basis
Pulled the trigger today & ordered the tein basis coilovers & spc front & rear control arms camber kits- in so excited to close that gap lol
Old May 17, 2017 | 08:47 PM
Nice to bite the bullet and get all the parts to get things set up properly from the start, look forward to the install.
Old May 17, 2017 | 09:24 PM
Kpmikey808's Avatar
Kpmikey808
Do u think front is flush or I need a small spacer
Overall is a spacer bad? Do they get stuck sometimes
Old May 17, 2017 | 09:32 PM
I'd get the suspension lowered & aligned then reevaluate, you might like the fit as-is and if you want a spacer you'd be able to determine the size needed much easier.
Spacers aren't a problem, just stick to a brand like Ichiba, H&R or B2 Autodesigns, those are decent quality. Just need to torque to 80-85 ft. pounds and if they are bolt-on spacers use ONLY a 6 pt socket that's sitting flush as the stock nuts that come w/ the spacers are very easy to round off. Also w/ the bolt on spacers re-check torque shortly after install and every oil change.
Old May 18, 2017 | 07:23 AM
Kpmikey808's Avatar
Kpmikey808
What height is good for daily driving 26 3/4 all around FTG
Old May 18, 2017 | 08:38 AM
I was at 25.75" on B&G lowering springs, that was too low for me. Not fun to navigate steep drives, speed bumps, and especially the speed humps The Y-pipe and exhaust tips got shredded being that low too.
I got coilovers about 5 years ago and set them to 26.25" to the fender arcs and that 1/2" made all the difference, no problems now, sure you have to be more careful at times, but not something that takes away from the fun of these cars.
So in short, 26.25 to 26.75" to the fender arcs and you should be a happy daily driver
Old May 25, 2017 | 11:20 PM
Kpmikey808's Avatar
Kpmikey808
Tein 26.5
Went 26.5 all around - 450$ for labor for coilovers, front rear control arms & camber kit & alignment was included - I shopped over 10 plus shops for prices & they had the best- panda 🐼 auto - they just opened & they have 2year 24k mileage warranty - never heard of warranty on work before
trim.4454E93D-11B1-4A31-9224-760D66B86859.MOV
Old May 25, 2017 | 11:58 PM
Kpmikey808's Avatar
Kpmikey808
Old May 26, 2017 | 12:30 AM
  #29
Once I turn my head to the side that looks really good there Kp! Sounds like a fair price too!
Old May 26, 2017 | 07:35 AM
  #30
monytx's Avatar
monytx
Brad, you are freakin awesome man lol.
