Very slight rumble/vibration/shake when coming to a stop
Hello all -
So, as stated - car seems to have developed a very slight rumble/stumble/shake/vibration (no noise, just feel it a bit in the seat) when approaching a stop, right before coming to a complete stop and settling at the idle rpm, a little shudder. Then gone.
This is not a case of warped rotors as I have gotten them machined. The slight vibration only occurs right before coming to a full stop and only last a second or less. Any idea on what might be causing this? And are any other G owners ever had this kind of problem?
Do you notice the RPM's dip below your regular idle then come back up? If so, start with cleaning the throttle body and doing the relearn procedure as posted in the DIY section
Brake issues would be worse the faster you are going, so it's unlikely
08STLX
17
Mar 12, 2020 12:52 AM
