Slight Vibration at idle then gone
Hi guys! When I drive my car and I come to A stop, sometimes I can feel a slight vibration throughout my seats. After maybe a second or less after stopping, the vibration goes away and the idle is smooth. What could be the problem?
I am having a similar issue, and I noticed the RPMs drop slightly once in a while when stopped. Keep an eye on your tach to see if that's the issue. I don't know the answer but I would love if someone more knowledgeable than I could chime in
Try getting your local oil change place to do a transmission flush. Normally I'm not a fan of "flushing" as I think a normal drain and fill is usually sufficient, but they do need to empty out that torque converter of the old fluid to get the full benefit of the new fluid. Hopefully that would make it go away. I think I've paid my local place like $120 to do it. It doesn't take them long at all.
Transmission flushes arent indicated on these cars. The 3x drain and fill will get the fluid out of the torque converter just fine.
i dont know how you can get a full transmission fluid change for $120 when a case of matic-s costs more than that
I wonder how much they would charge if you brought your own Matic-S fluid.
either way, clean your throttle bodies first. The reason the vibration goes away in neutral is because the idle spead climbs when there is no load on the engine
dealer cost for the proper procedure including fluid is $250-300
